Voltage regular - OEM vs aftermarket
Discussion in 'XJ Technical Chat' started by Alain, Jun 7, 2016.
  1. Alain
    Alain Member
    My motorcycle shop recommended I might try to change my regulator/rectifier unit to fix the 'lazy' charging. they checked the brushes on the alternator and a few tests ($540 of repairs later) and determined the last variable was the regulator/rectifier.
    I see that the original regulator part is: 3G1-81960-A1-00. Has anyone experienced bad or good things with an aftermarket part, i.e: http://www.bikebandit.com/aftermark...orsport-electric-rectifier-regulator?m=147135
    Price difference:
    OEM: $247
    AFtermarket: $104
    This is pertaining to my issue on lights not flashing: http://www.xjbikes.com/forums/threads/signals-not-flashing-horn-not-working-when-stopped.92456/
  2. Jetfixer
    Ouch...that is why I do my own work!!! if the Shop charged you 540 $ and it is still not fixed , you need to talk to them about it.. this is wrong. If you have to try a voltage regulator, I'm sure you can find one on eBay cheap. I would not buy new unless you know 100% that is issue.
    dkavanagh and Lightcs1776 like this.
  3. XJ550H
