Voltmeter
Discussion in 'XJ Technical Chat' started by buzz500, May 13, 2008.
  1. buzz500
    buzz500 New Member
    Nottingham U.K.
    Hi,all,just replaced my guages unit for a mph one,the original is in km,the voltmeter was acting up,fluctuating quite bad,put the new one on and it`s still the same,charging system is working fine,alt brushes are new,new battery,new fuse box etc,anyone know what could be causing this?maybe i could connect a differen power supply lead to the voltmeter?
    Cheers all
    Buzz
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I would check for corrosion at the fuse box and that the battery connections are tight.
  3. paulg
    paulg New Member
    British COlumbia
    Do you have a separate multimeter to measure the voltage? You might have a bad regulator or a failed diode in the rectifier circuitry, either one could be checked with a multimeter.
    ---p
  4. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Especially if both gauges show the same anomaly in the electrical circuit should you be concerned. I definitely would be searching for the problem before it gets worse or spreads.
  5. buzz500
    buzz500 New Member
    Nottingham U.K.
    Hi.all,thanks for the replies,all electrics have been checked and are functioning fine! thats the mystery.voltmeter works fine untill over 12v then just wobbles about!
    Buzz
