wanted: 7/8in straight pipe
Discussion in 'For Sale, Trade/Swap, Wanted' started by bostonXJ, Mar 10, 2010.
  1. bostonXJ
    bostonXJ Member
    Mansfield, Ma
    Around 30 inches should be good. If anyone knows somewhere local to Boston where I can get some that would be great too.
  2. bigfitz52
    At your local hardware store.
    I went uptown (Capac has a pop of ~1700) and got a chunk of what is known as 'black pipe,' dunno what "size" it is, because that stuff is sized by ID. But it's GD close to 7/8" OD, I used it as a "temporary handlebar and convenient pivot point" while restoring my 550s.
    I suspect you have the same purpose in mind? If you want it as an actual handlebar, go get a "drag bar." Nearly straight but at least halfway functional.
  3. bostonXJ
    bostonXJ Member
    Mansfield, Ma
    I was thinking about going the drag bar route, but I'm not sure I like them. I figure for 10 bucks somewhere local I can try a straight pipe. I'm not going to be riding long distances, so comfort isn't a huge concern of mine.
    I tried a few local stores and didn't find anything...The closest I got at the big chain stores was 3/4in
  4. xjrookie
    xjrookie Member
    KENTUCKY
    if the black iron pipe mentioned above is ok try your local plumbing supplier they will have it,in whatever size you need
  5. bostonXJ
    bostonXJ Member
    Mansfield, Ma
    I'll have to give that a try, thanks.
  6. bostonXJ
    bostonXJ Member
    Mansfield, Ma
    I was getting frustrated not finding what I wanted using the 7/8 measurement. Then I started thinking, what's that measurement anyways? I took a small tape measure and measured the outer diameter of the stock handlebars and found a 30in straight pipe that was almost dead on. It mounts perfectly, though the grips need sleeves, but no big deal.
    I love the way it looks. Normally I'd post pictures, but it's raining like hell here and my bike is out of my basement and I don't have a garage. Check my build thread for updates... My thread
