Wanted- Clutch basket XJ750
Discussion in 'For Sale, Trade/Swap, Wanted' started by DeMentedToys, Oct 25, 2011.
  1. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I have a 1983 XJ750 that Im needing a clutch basket for. I need the small inner basket and the bigger outer basket with the bearing.
    I for sure need the inner smaller basket if anyone has and extra.
  2. hogfiddles
    If it's the same as the Xj650 maxim, I got one here, I believe.
    Pm me.
    Dave F
  3. Natan
    Natan Member
    Middleton, WI.
    650 will no work on the 750. I bought a bike with the engine apart. I mounted another engine. Make me an offer.
    Natan
  4. DeMentedToys
    DeMentedToys Member
    Durango, CO
    PMs sent!
  5. TIMEtoRIDE
    Good time to check this - I heard that the tooth count on the clutch is different from Maxim to Seca - T or F ??
  6. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I m not sure about that one. I don't see why there would be a difference between the Seca and Maxim if they are both XJ750...
  7. MiGhost
    MiGhost Well-Known Member
    The only difference between 650/750 clutches is the following
    5G2-16383-00-00 SPRING, CLUTCH BOSS
    This sits between the seat plate, and 1st clutch plate on the clutch boss. It is a wave spring that uses a higher tension on the 750 to handle the higher torque load of the motor.
    Otherwise all parts are the same for both 650/750.
    The 650 is listed as an assembly in the parts schematic. While the change of the spring required the 750 parts to be listed seperately.
    Ghost
  8. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Cool. Thanks. So either clutch basket will work.
  9. chacal
    MiGhost has the correct answer: identical except for the clutch boss spring, and, actually, the pressure plate springs are different between the 650 and 750 engines, but they can be physically interchanged (the 750 springs are a bit stiffer).
  10. bigfitz52
    Back to the first post for a sec.
    I believe you need a HUB as well; you referred to the "smaller, inner basket." The outer piece is referred to as the "basket" because of its shape, empty. It resembles a basket. The center piece is known as the "hub."
    Just wanted to be sure you're searching for the correct parts.
  11. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Thanks. Yes, the "hub" is the part I really need. But if someone had a good hub and basket, I'll take both!
  12. DeMentedToys
    DeMentedToys Member
    Durango, CO
    So I just broke clutch hub # 3, using the local yamaha dealer's special vice grippy tool to hold it while I tightened the center nut. That was my last one. If someone has one please message me!
  13. chacal
    We should have a good used one, along with a proper holding tool! Send me an e-mail and I'll get you all the info............
