WANTED: Opinions & Suggestions
Discussion in 'Hangout Lounge' started by Gamuru, Jan 20, 2008.
  1. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I've decided to repaint my wife's bike. She's found of a deep emerald green so I picked a Toyota Camry color that she really likes. I stripped the tank and side covers and am at the point where I'm ready to fix some minor dents with glazing putty and then hit it with primer.
    But, I'm a little hesitant to leap in. Why? The last thing I painted was a racecar and that didn't have to be perfect. This, on the other hand, is for the wife so I want it to look, well, awesome.
    Here's what I envisioned the bike looking like when I'm finished...
    Do you have any suggestions that will help me realize my goal?
  2. Polock
    quit playing with Photoshop and get out there in the garage :lol:
  3. jdpesz
    jdpesz Member
    Stanwood, Wa
    Want to paint my bike first, just as a practice run? :D
  4. jdpesz
    jdpesz Member
    Stanwood, Wa
    But seriously, folks........
    You could post this question in the tech section in pnwriders, or use the forum search tool first. There are some good bike painters in this area, and someone should be able to send some pointers your way. Nice color, BTW. Good luck!
  5. danno
    danno Member
    Union Springs,New York
    Gee,that looks like my my bike,only in green...
  6. Gamuru
    Gamuru Guest
    Granite Falls, WA
    It may be. I got the picture off here some time ago. If I recall, the bike was parked on the grass under a tree. I orginally used the bike in a Christmas greeting.
  7. Polock
    what kind of stripper did you use ?
    i think i'm going to need a new fuel filter
  8. Gamuru
    Gamuru Guest
    Granite Falls, WA
    A propane torch to melt the paint followed immediately with a brass wire wheel chucked up in a grinder.
    What the heck happened to that tank?!?
  9. Polock
    believe it or not i did that on purpose :)
    thats about half way thru about eight layers of paint with ace hardware extra strength stripper
    i don't know what the other owners were thinking but they used tough paint
  10. Polock
  11. stereomind
    stereomind Active Member
    Tulsa, OK
    ooooo pretty :-D
  12. RickCoMatic
    Sand-off the Paint with 80 Grit Sand Paper.
    Re-sand with 180, 220 and 320 until you get to bare metal.
    Fill the dents and dimples with Bondo or MarGlas NOT Glasing Putty!
    Sand the Filler to shape and contour's with 220, 320 and 400
    Sand the whole tank with 400
    Glazing Putty pinholes and scratches.
    Sand the Glazing Putty filled spots with 400 Wet.
    Prime the Tank with Self-etching Automotive Primer
    Wet sand the WHOLE Tank with 600 Wet
    Re-Prime
    Sand the 2nd Coat of Primer with 600 Wet - 800 Wet
    Rinse.
    Bring the Tank and your sides to a Body Shop and show them that they are READY to have Color Blown-on.
    Show-up with the Color, Parts and $150.00 in CASH.
    Offer the 150 for a Pro to blow-on the paint.
  13. Polock
    gee thats easier than making toast
    150$ kind of shoots the cheap paint job though
  14. RickCoMatic
    For a nice color ... blown-on by a guy who does it for a living and won't mess it all up and run the paint ...
    A hundred and fifty bucks is a bargain!
  15. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    WOW! 150.00 bucks is a great deal to have it done by a PROF. I just priced out the paint alone for my bike, not including the primmer, sand papper and time, it was 138.00. So if you can get it done for 150, and not have to worry about screwing it up (like I probally would), sounds good to me. I got a quote of 275.00 if I prepped it myself.
    Let us know what you decide.
    Mac
  16. RickCoMatic
    The PREP is the hard part. The repair needs to be absolutely perfect because when the Color gets blown-on ... ANY imperfection is going to stand-out like a big, fat, zit right on the Prom Queen's nose.
    All too many times,, people do the Prep and don't "Feel it" and don't "Eyeball" it critically enough for painting. So, whenn the paint goes on ... that little tiny flat spot looks like a place where you could land a plane. Or, an unfilled scratch or tiny pit mark looks like a Postcard from the Grand Canyon.
    After you have done what you think is a perfect Prep after repair ... wipe the area down with a clean, wet rag and eyeball the repaired surface in reflected light. You shouldn't see anything but a smooth, new surface to be painted.
    If the repaired spot has a flat spot where a contour belongs ... there's NO "Close enough". The work you did will look awful if you blow-on Color over any likd of imperfection; no matter how small.
    Since more than 90-Percent of the work repairing and preparing a part for painting is "The Prep" ... being able to skip the hard part and putting your Color in the gun and painting is a SMALL job for a talented hand at spraying -on paint.
    That's why you will get a spectacularly good deal from the painter if you present your work to him with all the real hard labor already done.
    If you develop a relationship with the Painter and go the extra mile and offer hang the parts in the spray booth and run for coffee or "Do some errand" while he's painting your parts ... it goes a long way toward getting a few extra coats of paint blown-on the parts.
    Be sure to tell him you'll volunteer to Wet Sand the Color after the Paint is dry. Wet sanding the Color will give you a smooth, "No orange-peel or fish-eye's" inn the finish.
    Then, all that remains is thoroughly rinsing the Wet Sanded painted parts, letting then dry and shooting the wet-sanded color with a few coats of Clear.
    Done yet?
    Not quite!
    Once you get the Clear on the parts and the Clear dries and hardens ... you can wet sand the clear to a "Smooth as glass" finish and then Buff-out the wet sanding dullness for a Head-turning, holy-crap, unbelievable finish that will be the best-looking paint job you can imagine!
  17. MiCarl
    If you have some florescent lights in your shop, laundry room, rec room etc. they can come in handy for this. Remove the diffuser. Then take your part and manipulate it while watching the reflection of the florescent tubes. The reflection of the tubes should form a nice smooth line except where it drops over an edge (side panels come to mind, reflection will kink as it flows around to the edge flanges). On a Maxim tank they should flow like they were laid down with a French curve.
    Anyplace the reflections of the tubes pinch together or bulge apart will be visible in your paint.
    Do this at various distances and angles to thoroughly check your work.
  18. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Right on. All are great suggestions! I've decided to paint it myself. I'm still fixing dents and scratches, but hope to make some headway on it this weekend.
  19. Polock
    60$ worth of paint, not counting the 14$ rattle can of primer
    somethings going to turn red
    Gamuru how's it going ?
  20. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I'm still working on it. I've been working a lot lately so I've not been able to pay as much attention to this project as I would like. I'm hoping I'll get my long weekend this week. If so, I'll be sanding and painting. WooHoo!!!
  21. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Be sure to alternate arms or you will get one arm stronger than the other. :lol:
  22. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I've been making progress on this project and wanted to throw up a picture of what I've got so far. I shot the first coat of green on a black-primered tank last night and am preparing to wet sand it this morning. I'm hoping to hit it with another coat and let it hang all day while am at work.
    Oh, and the Missus LOVES the color! :D
  23. jdpesz
    jdpesz Member
    Stanwood, Wa
    Hope you put a tarp over the couch before you paint! :lol:
    Looks great Don.
  24. RickCoMatic
    Don,
    You done gots yer MoJo woikin'!
    Looks like you'll be heading into the Season all painted-out.
    Good feeling ... ain't it?
    Just makes you want to wet sand the tank 'til its smooth as glass.
    So, do it!
    Go for absolute perfection and ultimate greatness!
  25. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    Man that's a sweet looking color, great job on it! Try using a little soap with the wet sand, it worked really well for me. Just make sure you don't drop it on a concrete floor after it's all done... like I did!
    Keep the pics coming.
    Mac
  26. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Thanks, guys! Right now I'm playing catch-up with the side covers (I hadn't even primed them yet :oops:). I want to shoot all the pieces simultaneously with this fancy two part clear, but it only has a pot life of 24 hours. So, when the time comes to pop the can's cherry, I need to be ready to shoot it all.
    2K GLAMOUR HIGH GLOSS CLEARCOAT
    Spray Max 2K Glamour High Gloss Aerosol Clear. A 2 component aerosol clearcoat that is easy to apply, flows smooth and dries to a long lasting, high gloss finish.
    • 2K clearcoat in an easy to use aerosol
    • Activate, shake and spray
    • Unique nozzle delivers spray gun results
    • Dries to a high gloss finish
    • Excellent weather and chemical resistance
  27. danno
    danno Member
    I am curious to see how the clear coat works out ...please keep us posted.I haven't been able to find this stuff around here yet.
  28. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I got home from my group ride last Sunday and the wifey said she posted to her blog and wanted me to read it. Here's what the clever little woman wrote:
  29. chacal
    But at least her bike has a happy petcock...... :)
  30. MiCarl
    Translation: This thing better be done before the next nice day.
  31. Gamuru
    Gamuru Guest
    Granite Falls, WA
    She's been a pretty good sport about having her bike torn apart. But she did express her desire to hear it run again. I better redouble me efforts. (Besides, I've got stuff on my bike I need to get done like fork seals and carb bowl drain screws.)
