warm up time
Discussion in 'XJ Technical Chat' started by elsphinc, May 19, 2012.
  1. elsphinc
    elsphinc New Member
    tahoe ca
    how long do think it should take an xj550 to warm up in 50 degree weather on a moderate traffic road, to where i shouldnt need any choke, without much of a pre warmup?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Less then a minute if it is properly tuned.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I agree less than a minute if carbs are set up right.
  4. bigfitz52
    Only sorta. Both of my 550s are properly tuned and maintained; and while you CAN take the choke off within about a minute or two of driveway warmup and ride away, it does take a few miles (about 5~6) before the motor gains its full "snap" without any enrichment. I think it's partly due to the fact that the YICS passages are larger in proportion to the intake tracts than they are on the bigger bikes that makes them a bit more "cold blooded."
    However, if your 550 Seca is taking inordinately long to warm up, and your valves and carbs are fine, check the condition of this thing: http://xjbikes.com/Forums/viewtopic/t=31872.html
