way to unseize a seized engine? please help!
Discussion in 'Hangout Lounge' started by schooter, Apr 24, 2009.
  1. schooter
    I jsut got my new engine put into my cb750.. and it may be seized, when i turn the jkey and try to turn it over, i can tell the starter is trying to move... what do i do to unseize it? can you put a tsp of oil in each cylinder and wait over night? isnt that what alot of people do? I have some 20w-40 oil that im ready to pour in. maybe ill try and crank the engine by hand, if i can produce more strength than it
  2. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    i'd try by hand first, pull the plugs to make it easier to spin(no compresion) other than that i'm not sure what it would do to the clutches, ect. but i've seen people use PB blaster before. but i'm not sure what it could damage.
  3. Polock
    go get a pint of Lucas De-seiz-it, put a quart down each plug hole then put the rest in the crankcase, change your turn signal fluid to strawberry then push the bike backwards 50 feet with it in reverse
    then press the Pkey
    nothin to it
  4. TIMEtoRIDE
    What happened to Mouse Milk or Kroil ??
    And what happened to your old 750 motor, that I asked you to compression test months ago??
    You painted a bike that did not run? Am I being too hard on Ol' Schoot?? the XJ Wizard?
  5. schooter
    damnit polock, you actually had me going, thinking there was an easy way to it..
    and yes time to ride, im a moron... never did a compression test cuz i dont have a guage... uuugghh, i drove my truck around for an hour really pissed off, jsut ring to blow some steam ,the i walked around walmart for a half hour, came home, and put some oil in the cylinders... i think ill try and put the bike in 5th gear and turn the rear wheel.
  6. MiCarl
    Polock left out the part about putting seafoam in the muffler bearings over night.
  7. hardlucktx
    hardlucktx Member
    Allen Texas
    Schooter I have never tried it with a motorcycle but have used liquidwrench in the cylinders on a couple of old truck with good results.
  8. JoeFriday77
    JoeFriday77 Member
    North Texas
    I've heard or brake fluid used before. If I was going to try something, I would give ATF the first shot though.
  9. schooter
    atf? is that a kind of brake fluid, lol damn.
    anyways, im writing this rite before i go to bed, i tossed some oil in the cylinders again, tried cranking it, and it moved a bit!!! though its stuck again.. so im gonna let it sit over night and when my dad wakes my up at 7 am, im gonna rush out into the garage and try it again.
    i have a nice medly of 20w-40, some mystery oil in a squirter, and john deere multi purpose spray lube... that stuff is useless...
  10. schooter
    well after searching around.. brake fluid or marvel mystery oil helps....
    anyone wanna spray some kroil in a little container and mail it to me? i dont have a credit card to do the google offer.. that stuff may work
  11. RickCoMatic
    You shouldn't have bought the engine without performing a Compression Test.
    Put the Engine on cardboard, fabric or set it in a small tire.
    Pull the Plugs.
    Use a Tool to get the Cylinder Readings.
    Run the Starter with Jumper Cables and a Car Battery.
    Look at the Readings.
    If the Engine don't spin or the Readings are below specs ...
    Say "Thanks but No Thanks" and leave.
  12. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    My dad ran his two cyl tiller when had no oil and seized it up. I pulled the heads and applied liquid wrench over night. The next day I took a 2X2 and gently tapped the pistons one after the other. After about 4 raps on each it freed up and has been running for 2 years since. It all depends on how bad the damage inside is though. This was a brand new motor.
  13. Great_Buffalo
    Shooter,
    How much are seized motors going for these days :-O>
  14. schooter
    approx. $248
    i may call the guy.. if he's honest... he may have f'up when he looked inside the engine and stuff, and maybe he'll refund the money, if not, I think I'm gonna go to emc cycle in yale and buy one...
    I have about 4 different things sitting in the cylinders right now.. hoping it will work.. and what i though was the engine turning over before, may have been the starter making soem kinda noise..
  15. Polock
    before you do anything drastic, are you sure the clutch is disengaging ?
  16. schooter
    well, the wheel spins in neutral if thats what you mean... i'm gonna pull off a cover and try and crank it by hand..
  17. Polock
    i'am sure it will but will it turn with the clutch in while in gear, that means the tranny isn't jacked and the clutch does something
  18. schooter
    alrite heres tyhe scenario, took off the magneto/ stator cover, and i can go backand forth about 1/2 crank, what does that mean?
  19. Polock
    "1/2 crank" as in 180 degrees, well either the pistons arn't stuck or you have the worst bearings in the world
    maybe something is jamming the primary chain
  20. jeepsteve92xj
    jeepsteve92xj Member
    Milwaukee, WI USA
    I cant say this is what your issue is:
    my motor would only rotate 350 degrees when i becan my project - someone had dropped a screw into cylinder 1 and 4. More or larger foreign items int he cylinder could limit movement to 180 degrees.
    One tool I still want is fiber optic scope to look inside stuff like that.
