Welding
Discussion in 'XJ Technical Chat' started by Lokitruck, May 5, 2015.
  1. Lokitruck
    Lokitruck Member
    Bealeton,va
    is it possible to weld a new bung onto the head for a exhaust stud bolt or will it mess up the head?
    Post up a pic of the damage you're dealing with.
    I know this (from personal experience)....welding aluminum takes a huge amount of practice to get right. You won't be doing the job yourself if it really needs to be welded.
  3. Lokitruck
    Lokitruck Member
    Bealeton,va
    I will not be doing it. Im going to take the head to the local machine shop who specializes in this kinda stuff
    In that case I don't understand why you're asking us. The machinist will tell you if a good repair can be made, and if it will be economically feasible.
    Off the cuff I'd guess that it should run around $100 to repair the hole. He'll likely be using a TIG machine, so warping should not be an issue. The machinist may elect to bolt the head to a fixture if the repair requires extensive work, just to be sure that it does not warp during welding. Bring him a new exhaust stud along with the head so he can match the thread. A box of doughnuts wouldn't hurt either (or his favorite scotch).
  5. Lokitruck
    Lokitruck Member
    Bealeton,va
    Honestly i asked the question before i researched the answer then when you responded i didnt want to be rude and not respond
  6. k-moe
    You did good. I hope that I didn't come off sounding too gruff in my reply.
  7. k-moe
    Dang.... I may be turning onto a Canadian.
  8. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    You say that like it's a bad thing, eh.
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    K-moe, if you were Canadian, there would be an apology here. All you did was explain yourself. Also, a Canadian would bring his machinist BEER! Just a pointer. Sorry aboot the confusion!
