well shoot
Discussion in 'XJ Technical Chat' started by MarkInKansas, Sep 28, 2011.
  1. MarkInKansas
    MarkInKansas New Member
    Kansas City
    was working on my carbs yesterday and discovered this:
    carb cleaner seems to eat whatever kind of glue this is, so i scraped it off and was left with this:
    anybody have a spare mikuni float bowl? suggestions for some kind of glue/epoxy that will stand up to gas and carb cleaner that i can patch this up with?
    thanks in advance.
  2. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    JB Weld! Used for automotive repairs can be used on anything. When hardened it can be even drilled and tapped! There are two types of JB Weld one takes 24 hours to cure and then there is JB Kwick which is a fast setting epoxy. Its OK for non critical repairs. I prefer the regular JB Weld.
  3. dwcopple
    dwcopple Active Member
    bay city, michigan
    jb weld will do it as will the jb putty
  4. bigfitz52
    Just replace the float bowl.
    Get ahold of chacal (XJ4Ever) or put a post in "Sell, Trade, Swap, Wanted" it's not worth trying to fix something that critical and so easily replaced.
  5. Ground-Hugger
    Well at least with jB Weld you can still ride till you receive the replacement!!
  6. bigfitz52
    How are you gonna set a float level with THAT (or expect it to accurately hold a level that was set using a different bowl?)
    Plus, it's a Mikuni. And the enrichment passage is near enough to the scene of the disaster that I wouldn't.
    On top of that, the stuff you scraped off appeared to be JBWeld.
    Seriously, replacement float bowls for the BS28s aren't hard to find, honest.
  7. SQLGuy
    SQLGuy Well-Known Member
    If you have trouble finding a replacement float bowl and/or think you might need to repair aluminum and various other metals in the future, I can definitely recommend Muggy Weld. I bought some of their Super Alloy 1 to repair an A/C evaporator where I needed to solder copper to aluminum. It worked like a charm on that, and I've since used it for a number of other repairs, including cast aluminum parts. It's pretty strong solder that melts at pretty low temperature (about 350F).
  8. RickCoMatic
    I have some Float Bowls.
    Some Hitachi.
    Some Mikuni.
    Every last one of them in near perfect condition;
    EXCEPT:
    Clogged Enrichment Jets / Well.
    Seized Drain Screws.
    PM me if you want one.
