Wet set method
Discussion in 'Hangout Lounge' started by tabaka45, Jan 11, 2018.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    The service manual for my son’s Yamaha Grizzly 80 4 wheeler says to level the carb by jacking up the front end, attach the clear tube, start the engine, and then take the reading with the engine running. Ever heard of that?
  2. hogfiddles
    Interesting....
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Do they give an angle or height to jack the front up to? Seems sort of imprecise.
  4. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Yep. Page 87 of the XJ1100 download manual states the same.
    I think the FJ's and the XJR's use the same method. I've never used that method so can't really comment. On my XS/XJ1100 bitsa I just use the standard float height method.
  5. k-moe
    Think about what we do when we wet set on the bench after a rebuild. Same, same.
  6. tabaka45
    Brunswick, Georgia
    I assume you jack it up until the carb is level. Anyway, I leveled it when I wet set the float—not on the bike so not the running method.
