WET SETTING FUEL LEVELS
Discussion in 'XJ Technical Chat' started by wizard, Nov 10, 2014.
  1. wizard
    WET SETTING FUEL LEVELS 001.JPG WET SETTING FUEL LEVELS 002.JPG WET SETTING FUEL LEVELS 004.JPG
    Is this a novel idea, cut 50mm off the bottom of a clear plastic bottle.
    Now you can really see what is going on.
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Interesting, but how do you get the gas out when you are finished?
  3. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Novel indeed but are you using it to measure anything? The plastic would have to be formed in the shape of the bowl to accurately set the float height, correct?
    Gary H.
  4. tcoop
    tcoop Active Member
    South Weber, Utah
    No, the float is affected by the level of fuel not the volume of fuel. I'm not sure I would try this but wizard thinks it works great and you don't have to mess with sticky bowl drain valves.
  5. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
  6. rocs82650
    Middle Tennessee
    Volume in the bowl will raise or lower the fuel level. The inside shape and size of the bowl determine how much (volume) fuel it will take to reach spec level. The floats rise with the level and is adjusted to shut off the amount of fuel in the bowl at the desired spec level. Kinda' works like the set up in a toilet tank.
    Gary H.
  7. wizard
    Level is level even if the bowl was 50 foot diam'.
    Just thought, you wouldn't even need to remove the bowls to CHECK the level, just remove the drain plug, as long as the plastic bottle was wide enough.
  8. rocs82650
    Middle Tennessee
    You're correct. My apologies...i had a brain fart last night. You're not measuring how much fuel it takes to reach spec level. You're setting the tang to shut off the fuel supply in the spec level plane. My bad. I'll shut up now.o_O
    Gary H.
  9. Bigshankhank
    Bastrop, TX
    Still, how do you drain it without spilling anything?
  10. rocs82650
    Middle Tennessee
    More novelty. Something like the thing we use to remove the oil around the cams to check valve clearance (a snot cleaner for babies). He only needs to remove enough fuel for the level to drop below spec.
    Gary H.
  11. Bigshankhank
    Bastrop, TX
    So you've shifted the effort downstream. It's easier to check the level, but harder to drain the bowl in order to make adjustments to the float.
    Novelty, yes but thats it. Not really a solution to the question of making wet-setting floats any easier.
  12. Polock
    he uses scotch whiskey and a straw :)
  13. Bigshankhank
    Bastrop, TX
    See, now THAT'S a solution to a problem!
  14. wizard
    Still, how do you drain it without spilling anything? (quote)
    Big funnel into the gas can, flick off the wire 'cradle' & your good to go again.
    I only tried this method as these bowls don't have a spigot for a clear tube.
    It is the quickest, easiest, surest method I've ever used.
    TIMEtoRIDE likes this.
  15. rocs82650
    Middle Tennessee
    I've got $5 on it!:)
    Gary H.
    dizzycow likes this.
  16. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    wizard.. let alone looking damn cool... the premise is very groovy!
  17. TIMEtoRIDE
    Instead of using the BOTTOM of the bottle, use the TOP with the twist-off lid.
    or
    glue on a drain tube and golf tee. I like the idea.
  18. bigfitz52
    I have a question:
    Where are the FLOATS?
    I don't see any floats in the pics. Was this just a "proof of concept" and you need bigger bottle bottoms for room for the floats?
    Or am I missing something?
  19. hogfiddles
    Fitz.......look again--they're right there at the top. That's what the black is. You're getting distracted by the refraction and distortion. Look at the floatpin and let your eyes follow around.
    We're used to seeing the floats at an angle. But here, they are floating up into their chamber tops, so all you see is just a little of the floats.
    Dave Fox
  20. wizard
    "There are none so blind as those that will not see" (quote: John Heywood 1546 ad)
