What are the three holes located right under the throttle plate?
Discussion in 'XJ Technical Chat' started by DarrenH, May 13, 2016.
  1. DarrenH
    DarrenH Member
    Michigan
    These three holes appear to be a bit more difficult to clean than the rest of them and I'm not even sure what they do. Any insight?
  2. DrewUth
    DrewUth Active Member
    South Jersey
    Those are for the pilot circuit. They are important.
  3. chacal
  4. DarrenH
    DarrenH Member
    Michigan
    So how can I reach those holes to clean them?
  5. chacal
    Typically, carb dis-assembly followed by high-pressure (i.e. spray can) brake cleaner or carb cleaner. Air compressor is handy, too.
  6. a100man
    a100man Well-Known Member
    Bedford, UK
    As said above -very important, they connect back to the pilot jet that dips into the float bowl. You should unscrew the pilot jet
    (of each carb) and attempt to to squirt carb cleaner through until it appears out of the three holes - without hitting your eye. 'You may have to attach a small diameter feed tube from your can of carb cleaner to the pilot jet orifice. Use compressed air if you like but you cannot then 'see' the flow like you can with liquid,
    Bon chance
    James
