What are your prime XJ likes & dislikes?
Discussion in 'Hangout Lounge' started by faffi, Aug 14, 2022.
  1. faffi
    faffi Active Member
    Norway
    I suppose the majority of members only have one model, but if you have several, please specify what qualities you are particularly happy with and unhappy with for each.
    Although I no longer own an XJ, I vividly remember my 1983 XJ750 Seca. So here goes, most important ones in bold:
    PROS
    Durable engine and drive-train
    Low maintenance shaft final drive
    Strong braking performance
    Narrow engine
    Incredibly flexible power supply
    Easy general maintenance
    Anti-dive fork
    Drum rear brake
    Twin rear shocks with adjustability
    Looks
    CONS
    Hand-numbing engine vibrations
    Severe shaft drive torque reactions
    Wire + hydraulic front brake operation
    Narrow rims lacking correct tubeless bead design
    Too eager low fuel level warning light
    Restrictive riding position
    Relatively harsh suspension
    Poor paint finish on engine and frame
    Ugly plastic cover over handlebars and top triple clamp
    Could have used a bit more cornering clearance
  2. Oblivion
    Oblivion Active Member
    Northeast Illinois
    It's been about 11 years since I've ridden my '81 Seca (hopefully this fall!), but my list would be pretty similar to yours other than:
    Mine has crash bars with highway pegs, which opens up a couple different riding positions.
    The triple-tree cover doesn't so much bother me aside from it making farkling difficult.
    One con I'll add (again, it's been a while) is I remember the front suspension being VERY prone to wobble if the fork was at all out whack (different air pressures in the tubes, leaking seals, old oil, etc.). NEVER considered riding her no-hands.
    After riding my Yam. WR250R pretty exclusively for the last decade+, I'm curious what getting back on the heavier, more powerful, less-agile, shaft-driven Seca will do to my head. Once upon a time, I was so tuned into those drive shaft quirks, and rev range, that switching between the two was a mental exercise/re-calibration.
    I'm also looking forward to hearing 'that sound' again. Assuming the exhaust system is still good - the one thing I haven't been able to inspect/test/check/break down yet.
    faffi likes this.
  3. hogfiddles
    Front end wobble is often due to bad/loose steering stem bearings, but can also be a result of swing-arm bearings, too...... check them.
  4. Simmy
    PRO
    - XJ's are like Meccano building sets, easy to mix and match parts
    CONS
    - thinking about mixing and matching shit keeps me up at night
    Dallaswb, jayrodoh, chacal and 3 others like this.
  5. chacal
    May need to get it pulled and do a valve job......
    Oblivion likes this.
  6. Jetfixer
    I love my Seca so much I built another. I have had several bikes over the years , by far the Seca is my favorite, I can ride all day and not feel like stopping every 25 miles . When you have your carbs right, starter clutch is not slipping ( I have replaced two starter clutch in two separate engines) I upgraded mine with spin on oil filter conversion, caged roller head bearings, stainless steel braided brake lines, AMG sealed battery. I added the Yamaha hard luggage, and the sport fairing.
  7. Dave in Ireland
    Ireland
    Pros:
    Shafty
    Economical - can easily get 45mpg on a spirited run around the back roads and more if I put my mind to it.
    Powerful enough - reputed 98bhp is enough for me.
    The fairing - at about 90mph the fairing, which looks too small to be of much use, suddenly acts like it's a bigger unit and diverts air above and around the rider.
    Tyres are available in easy and cheap-ish sizes.
    24L tank - can go for a long time if being driven sensibly.
    Servicing - shims easy, cheap air filter, most other parts not too bad in price.
    Spin-on oil filter conversion suddenly turns a messy and awkward job into a breeze.
    Cons:
    Original headlight is a bit crap - an LED kicked that into a new dimension.
    OEM pipes and aftermarket pipes don't last long and Delkevic don't make any.
    Jetfixer likes this.
  8. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I rode the 550 more than any other.
    Pros:
    It's a very "right size" bike.
    Great power for size and weight.
    After the initial round of repairs, very reliable.
    Fairly easy to work on, most things are pretty accessible.
    Parts availability is amazing for something that old.
    Cons:
    Carburetors are a right pain in the ass to get right. Also annoying to remove/replace.
    US-spec single-disc brake could be better.
    Jetfixer and cgutz like this.
  9. Dallaswb
    Dallaswb New Member
    Us
    82 xj550 seca and 81 xj750 seca. The 550 I built from the frame up so I can't really say as to any cons of 550 because I made everything the way I wanted anyways. Now the 750 I have some problems with. The anti dive on the front suspension is unnecessary and just adds weight, shaft drive shaft drive shaft drive Gd shaft drive, why. My opinion is it's a very ugly bike. I'm not a fan of the swirl rims or the way the seat mates into the tank it needs to be a lot lower give the tank more definition in the profile. The tire selection is limited, LED conversions are needed, the service manual is a dirty liar. No change driven 6 gears other than the 550 model.
    Pros: I have an 81 Suzuki gs750 and a 79 Honda CB750 and of the three xjs fastest.
  10. XJ650inTexas
    XJ650inTexas Active Member
    Dallas
    Geared for a time when the speed limit was 55 so now that it's 70 or 75 she's up on the pipe a bit
  11. hogfiddles
    But it doesnt bother the bike one bit.....
  12. Melnic
    Melnic Active Member
    1983 XJ 650 Maxim
    Pro
    SMOOTH running engine (when its running)
    Comfortable handle bars
    Plush seat
    Alloy and not spoke rims
    CHEAP OIL CHANGE! $17 / Gallon Rotella T4 at Walmart
    XJ4ever is a savior for hard to get parts found no where else
    Low seat height, low center of gravity (ok, comparing to my Harley Sportster which is top heavy)
    Con
    Petcock fuel line to carb path does not lend itself easy to add a filter w/o running line with a vertical hump to trap air.
    Foot pegs a bit close to seat making my knees bend more. Added highway pegs to engine guard.
    Adjusting idle screws on inside 2 carbs painful unless you remove / raise tank.
    Unlike some other older bikes that are more popular, not a good aftermarket parts. Many of what is sold does not fit, is crap or just worse than original.
    RE: Removing carbs. I guess i've pulled/replaced them so many times I find it not so bad. Heat up the rubber with heat gun enough to get hot but not melt and I can push them into or pull from intake boots just fine. I can pull tank, remove carbs in about 15 mins. Putting back in is about 20 mins.
  13. Bryce W
    Bryce W Member
    Virginia
    A big con I have is the gas tanks my X only comes with around 140 miles of range. Wish I had 5 or 6 gallons....
  14. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    XJ700N
    Pros: Pretty much what everyone else has said.
    Love the power and response--even though I've never been close to red-line.
    Con: Wish it had a 6th gear for cruising
    Would like a slightly larger fuel tank
    Problem finding the correct spark plugs
    Not a big fan of shims for adjusting the valves
    Huntchuks and Jetfixer like this.
