  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Did the bracket fit the carb? Or did you twist it like that?
  2. LarryMc
    LarryMc Active Member
    Lakewood, WA
    That bracket is a duplicate idle speed screw bracket from a junk set of BS28 carbs. Yes, I twisted/bent it. The screw extender came from ebay with no means of attaching it so I improvised.
    I'm sure it's from a later year Yamaha that had Mikunis. I'm doubtful it was off a FZR750 because they ran Keihin carbs mostly and the carbs were covered by a fake gas tank plenum. Who knows?
    I knew the screw threads were the same so I snagged it for $12.00. I have trouble accessing the idle speed screw in its usual location plus it gets pretty toasty there also.
    Works great for me.
    Jetfixer likes this.
  3. turpentyne
    turpentyne Active Member
    Desert SW
    NO! I don't like that idle screw at all! ... because I put my carbs back on a couple weeks ago, and now I wanna do that!
    Tim O and Jetfixer like this.
  4. LarryMc
    Lakewood, WA
    Pull them off the bike and install one. There are at least a dozen on ebay right now for sale. I just looked, seriously.
    Pulling and reinstalling the carbs gets easier each time you do it, once you figure which way works best for you. You got this....
  5. 78dave
    78dave New Member
    Columbia, MO
    New throttle shaft seals did not help with hard starting when cold.
  6. LarryMc
    Lakewood, WA
    Check your valve adjustment, make sure your getting good spark, is your battery charged up completely and if it's really really cold where you live these bikes can be real twats until they are warmed up.
  7. 78dave
    78dave New Member
    Columbia, MO
    I will say I think I did get an improvement when the choke is off. Mine has never run for any duration with full choke. But now when I use the choke a few times then go without it I notice a longer very slow run as it is trying to warm up and I can lightly dial in some throttle. Yes cold here.
  8. LarryMc
    Lakewood, WA
    Sounds like you might have a vacuum leak or a screwy enrichment plunger. Something along those lines. The first thing to do is check your spark plug color and that will tell you a bunch of info. Without seeing the plugs, I'll venture a guess that your bike is a little on the lean side from what you've told us. Pull the plugs, get a new set and fiddle a bit with your mixture ratios or Colortune. If you don't have a Colortune, get one.
    My finicky cold start issue went to starts with no or little choke after I bought a Colortune. Also I was surprised how much the mixture screw settings varied between each other.
  9. Abaton6
    Abaton6 New Member
    Hartland, Vt.
    \What does Rick charge for the carb rebuild?
  10. LarryMc
    Lakewood, WA
    Got some ME time today and got everything 99% put back together.
    chacal, kosel and Franz like this.
  11. xHondaHack
    Orange CT
    Larry, that looks awesome! Saw your other thread where you got some ride time on it.
    Wish I had more time to document all the stuff I've done or plan on doing.
    In the meantime, here's a snap shot of the parts bike build after my 20 mile shake down run today:
    I do have the "5 Valve" carb and airbox trim pieces. I'll be installing those after the final jetting when the weather gets warmer.
    One of these days I'll do a build thread with close ups and details on all the mods and improvements.
    Tony
    rocs82650 and Jetfixer like this.
  12. LarryMc
    Lakewood, WA
    Thank you.
    Your ride is undoubtedly very nice. Great work on keeping it up.
    Let us in on what work you have done.
    Its always interesting to see what others are doing to there bikes XJs or not.
  13. LarryMc
    Lakewood, WA
  14. Joeoeo
    Joeoeo New Member
    NC
    Rainy day here so I spent it doing what was sorely needed...
  15. Tim O
    Tim O Active Member
    Charlottesville, VA
    I have the same one... warning, I had to tuck it farther up under the tank as the seat was pushing hard on the top of it even with the plastic plate removed from the seat.
    Joeoeo likes this.
  16. Joeoeo
    Joeoeo New Member
    NC
    hmm ill keep an eye on it. seemed like there was enough clearance to not have issues, ive heard of people also using seat spacers to lift the seat a few mm
  17. LarryMc
    Lakewood, WA
    * Update *
    Regarding the extended throttle adjustment knob installed during my carb overhaul:
    The mounting point off the carb bowl screw didn't work out. It also created a conflict when reinstalling the carbs.
    With the same mounting bracket flatten out and a larger diameter hole, the upper starter mounting bolt was replaced with a slightly longer one and the knob fits there nicely. Pulling and installing the carbs is not an issue with this mounting point. Just let it hang until the carbs are secured then install the bolt back on the starter. The idle is easily tweaked here, if needed.
  18. Jetfixer
    Just came home 50 degrees, started bike up , been sitting for a few weeks . I WANT to ride , but have bike tucked on side wall just right to get my truck in garage...must resist now if we get no real snow for rest of winter:D
    Chitwood likes this.
  19. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Hit 45 here today...if it wasnt for all the salt on the roads I would have pulled it off the breezeway and went for a rip
  20. Franz
    Yes l don't mind the cold but the road salt is bad. Hopefully winter will be mild time will tell.
