what does the bike actually NEED?
Discussion in 'XJ Technical Chat' started by Danwoods, Aug 3, 2016.
  1. Danwoods
    Danwoods New Member
    chicagoland
    as bad as it sounds, i am looking at a very stripped down project that needs a lot of work. with wiring harness is gone completely along with the entire speedo cluster, handle bars, levers, controls, cables, ect.
    i can source a new carb and exhaust, and install no problem but the wiring is what makes me nervous.
    is there a setup that i can buy that will give me a no frills bare bones working bike? like a painless wiring system?
    push button starter and ignition timing? thats really all i hope i need. brake and turn lights are a perk but not a necessity.
    thanks in advance.
  2. dkavanagh
    Rochester, NY
    There's a thread on here about a minimal wiring harness that might help you out.
  3. Danwoods
    Danwoods New Member
    chicagoland
    thanks. i was poking through the manual as well, but that just says dont repair the tci.
  4. dkavanagh
    Rochester, NY
    you should probably use the TCI since it was designed to work with this engine (and does a good job). You likely should retain the circuitry associated with charging like the regulator and diode block. But, I don't want to re-hash.. Let me find that other thread.
    http://www.xjbikes.com/forums/threads/minimal-wiring.66321/
  5. Toomanybikes
    Tsawwassen bc
    Lots of the members have spare bits.
    I have a box of xj750 stuff . I'll dig through it and let you know what I have
  6. Danwoods
    Danwoods New Member
    chicagoland
    i have an 82 xj750 maxim.
  7. Danwoods
    Danwoods New Member
    chicagoland
    that is an issue in itself, i tci was accidentally discarded.
  8. dkavanagh
    Rochester, NY
    Well, like "toomanybikes" mentioned, he has stuff.. people have stuff.. you can get all the stuff you need. Question is how much.. and shopping around, you'll figure out what that is.
  9. k-moe
    Same bike, yes? http://www.xjbikes.com/forums/threads/xj750-project-bike-parts-bike-near-chicago-milwaukee.97664/
    You need a bike in better condition, and use yours as a parts donor.
    Just a TCI and wiring harness will set you back about 1/4 the cost of recomissioning a bike that's all in one piece (even if you build a minimal harness).
    If the machine has sentemental value than it's worth doing, otherwise consider it a parts bike. There are just too many relatively-expensive things that are missing.
    If your goal is to build it to sell then you're going to end up way under the water on it.
  10. Danwoods
    Danwoods New Member
    chicagoland
    yeah, thats me. im weighing the options of just getting the bike in running condition and just getting it gone.
    the numbers are definitely against me. no real sentimental value, im just trying to see it through.
  11. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Dan,
    "Nothing is more difficult, and therefore more precious, than to be able to decide."
    You have a decision to make, I am not sure of all the circumstances surrounding this decision but given the purging of parts from your garage I am going to ass-u-me that there may be some heartache involved also.
    My .02 cents; sell it on Craigslist as 'part of a parts bike' take whatever they will give you and move forward. Keep an eye out for another complete XJ that 'ran good last year', buy it, don't bob it - restore it (with help from here) and feel good.
