What else is wrong in the XJ550 factory manual?
Discussion in 'XJ Technical Chat' started by pjb03, Oct 16, 2012.
  1. pjb03
    pjb03 Member
    Santa Fe, New Mexico
    I replaced a head gasket. Took it for a ride, and after 20 miles noticed my leg and boot had oil on them. I may have a rubber o-ring where it's not supposed to be. I followed the directions on page 3-31. My manual p/n is lit11616xj-50.
    Thanks for any help.
  2. bigfitz52
    Or NOT have new copper sealing washers on the (2) bolts where they're critical?
    Where is all this oil coming from?
  3. pjb03
    pjb03 Member
    I didn't use new copper washers.
    The oil is coming from the right front.
  4. bigfitz52
    Bingo.
    As in, right SIDE, from the head/cylinder join, or at the head bolts?
    The two head bolts on the RH side, adjacent to the spark plug hole, get copper sealing washers. At the head/cylinder join, their locating dowels get o-rings in the grooves around them.
    That's because the oversized bores those two bolts go through are the oil feed galleries to the head/cams. Pressurized oil is fed through there, (the front one feeds the exhaust cam, etc.)
    If you didn't replace the o-rings at the head gasket join, left out the dowel pins, or didn't replace the copper sealing washers on the top side (under those two crown nuts I mentioned) guess what? It's gonna leak. Hot, pressurized oil is persistent. (Trust me, I still ride a British bike.)
    What is the error in the factory book? (These things are covered.)
  5. pjb03
    pjb03 Member
    3-31 shows 3 rubber o-rings on the oil feeds. There should only be 2. It's leaking from the head gasket. The copper washers still seal. It's that 3rd o-ring that's causing the problem.
  6. bigfitz52
    Urk. It sure does. And that third hole only gets a dowel pin IIRC.
    I think I know why: the book is actually based on the original XJ400 (there are a couple of photos that give it away) and THAT motor may well have had an o-ring there.
    Good catch. Sorry you had to spot it the hard way.
