What hertz from coil to tachometer
Discussion in 'XJ Technical Chat' started by Aussie, May 10, 2022.
  1. Aussie
    Aussie New Member
    Hi, I have a 1982 Maxim 650 and the tach is dead. I am getting it rebuilt, the question I was asked is what is the hertz at idle (1260 rpm) so the mechanic can set it during the rebuild?
  2. SQLGuy
    SQLGuy Well-Known Member
    Since it's wasted spark, the coil fires once per rotation of the crank. So, 1260 / 60 seconds per minute = 21 Hz.
  3. Aussie
    Aussie New Member
    Thank you for the quick reply. Life saver. Cheers, Mate!
  4. Aussie
    Aussie New Member
    Because there are two coils does this mean you have to double the hrtz for the tach?
  5. k-moe
    No. The tachometer only receives signal from one coil.
  6. chacal
    Out of curiosity, who is repairing your tach?
  7. Aussie
    Aussie New Member
    Cheers. The company is Humphrey Instruments in Unanderra, NSW
  8. chacal
    Thank you for the info. Can you give us a little more info as to what they are replacing, or are they building a new circuit board for it, or ?????
  9. Aussie
    Aussie New Member
    He built a new circuit board and calibrated it to the RPM and hrtz. Quick turn around 3 days. I should get it back on Monday.
  10. chacal
    Please let us know how it looks and performs!
