What is going on here>?
Discussion in 'XJ Modifications' started by dykema, Mar 14, 2012.
  1. dykema
    dykema New Member
    Chadwick, Illinois
    Looks to me like someone put this together wrong... there is a small exhaust leak. What are the rusty metal pieces? they look like a kind of gasket but they just dont look right to me. Should they be turned around? there are 2 of them on each header.
    The system is a 4 into 1 Vance & Hines.
  2. markie
    markie Member
    Suffolk, England
    They are collets. The exhaust pipe has a flange welded to it which the collets push against. The header clamp pushes against the collet to form a seal between the flange, exhaust gasket and cylinder head. The gasket is made from aluminium and some heat resisting material. If you have a leak, the gasket is likely to be missing!!
  3. dykema
    dykema New Member
    Chadwick, Illinois
    so are they supposed to look like that? are they in there correct? thanks
  4. venlis
    venlis Member
    Finland
    both have a flange, the collet and the header.
    iirc exhaust gasket in the exhaust port, collet on the header, flange facing forward and then the header clamp tightened to spec
  5. MiGhost
    MiGhost Well-Known Member
    Just to clarifiy this a little bit.
    The flange on the collet faces into the clamp ring. Away from the engine. this gives the collet a lock in the clamp ring, and clamping force against the flange on the exhaust.
    Over time the collet will degrade, and loosen. Allowing the exhaust to leak. If they show any signs of rusting you are better off replacing them.
    Ghost
  6. venlis
    venlis Member
    Finland
    thanks mighost :)
