what is the fuel tank hold down bolt size
Discussion in 'XJ Technical Chat' started by fleetsailor1981, Jul 18, 2012.
  1. fleetsailor1981
    fleetsailor1981 New Member
    Guys I need some help finding the size of the bolt that holds the fuel tank on a 81 XJ650. Mine was stolen over the along with all of my tools. I had the tank off getting repaired. This my first bike in 34 years and want go get it running so I can get out and enjoy myself. Thanks Gregg
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Re: Help......
    Please be more descriptive in the topic line. So members that know the answer to your question can see and answer more effectively.
    MN
  3. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Re: Help......
    I don't know on the xj650 however if you have an owners/service manual in most cases the specs should be listed in there.
  4. moellear
    moellear Member
    Lima, Ohio
    Huh?
    Its either 10mm or 12mm by 12 or 16 mm in length. If you have access to a generic hardware store like Ace Hardware or even Menards, they should have drawers and drawers of nuts, bolts, and washers. Twenty & some cents later, and you'll have a bolt that holds the fuel tank.
