What is this part called?
Discussion in 'XJ Technical Chat' started by losifer, Apr 17, 2010.
  1. losifer
    losifer Member
    Minneapolis, MN
    Four questions about this part, found under the seat behind the battery.
    1) what is this called?
    2) what does it do?
    3) can it go bad?
    4) what is the correct wiring to it?
    Thanks.
  2. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Try this link for more info:
    http://www.cheapcycleparts.com/model_ye ... ies/157106
    Ref
    # Part Name Part Number Quantity # Required
    Per Assembly List Price Your Price
    001 STARTER SWITCH ASYASSY 36Y-81940-00-00 1 $78.84 $54.69
    002 NUT 95380-06700-00 2 $1.06 $0.74
    003 WASHER, SPRING 92995-06100-00 2 $1.00 $0.69
    Hope this helps a bit.
    Graham
  3. wizard
    have you got 2 thin wires not shown on the picture?
  4. skills4lou
    skills4lou Member
    Dillon, MT
    1.Starter solenoid.
    2.Connects the starter to the battery when you hit the switch
    3. Yes, but if there's a problem it's more likely in the connections that the actual solenoid.
    4.Heavy gauge wire from battery + to one of the big connections.
    Heavy gauge wire from the other big connection to starter
    Small gauge wire from starter relay to small connection on the edge
    small gauge wire from other small connection to ground
    On my bike the small gauge wires are soldered.
  5. losifer
    losifer Member
    Minneapolis, MN
    Thanks for the quick replies.
    Does it matter which of the big connectors the battery "+" goes to? or are they interchangeable?
    Also, I only have one small-gauge wire going from it to the starter relay. I don't have it grounded. If I were to run a ground wire from the other small post, where should it go to for proper grounding?
  6. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Yes they are interchangeable.
    There should be a Blue/White wire that comes to the relay, that is from the start button. There should also be a Red/White wire that comes from Starter safety relay.
    Power comes from the safety relay, through the starter solenoid, and is grounded by the start switch.
