What kind of mileage do you get on your XJ?
Discussion in 'XJ Technical Chat' started by Lefty, Jul 22, 2007.
  1. Lefty
    Lefty Member
    Vancouver, BC
    Haven't yet ridden through a full tank of gas from start to finish, so I have no idea what to expect from my bike.
    Anyone want to post ballpark figures? How far can you go on a tank? How often do you fill up?
    C
  2. Earl-R
    Earl-R Member
    St. Louis
    I get about 45-50 on my 700S if I don't get on it. I can almost go a week on 1 tank of gas.
  3. Sbmaxim
    Sbmaxim Member
    took close to 70-80 miles to hit my reserve, I could be off slightly, but that should be close.
  4. MiCarl
    Just filled mine up tonite. About 40 mpg mixture freeway (70MPH) and surface cruising at 40. Also, lost some because I drained the carbs to put in new needles and seats and clean clogged pilot wells.
    I've found that cruising surface highways (50 - 55 with few lights or stop signs) I get about 45. Doing 70 on the freeway I get 35.
    Rule of thumb, set the trip odometer to 0 when you fill up. At 100 miles it's time to fill up again. If you're above 90 miles and it aint running right put it on RES and get gas soon.
  5. Sonwatcher
    Sonwatcher Member
    Central Pa
    Just running normal up to 55mph I have gotten 54 mpg. I just took a 400 mile trip going 65 or so and got in the upper 40's. I usually always fill at 100 miles but during a bike ride I went around 130 miles and didn't hit the reserve.
  6. Artjim
    Artjim Member
    Arkansas
    48 to 50 mpg.
    ___________________
    '85 XJ700 Maxim X
  7. Nick
    Nick Member
    Vernon, BC Canada
    Lefty, on my XJ750 I'm averaging 215 km per tank, 7 L/100 km, which is a hair over 40 miles per imp gal. Most of my driving is back and forth to work in town. A bit of highway travel on weekends.
    I've never pushed it to empty, I need to switch to reserve around 190 km and then get to a gas station.
  8. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I'm about the same as Nick. At 200 kms and I'll be into reserve and not passing any gas stations. After a couple hours in the seat, it's time for a break anyways!
  9. MNXJ650J
    MNXJ650J New Member
    Maplewood, MN
    82 XJ650J and I have gotten between 45 and 51 MPG since I picked this bike up this spring. That's about 10 tank fulls so far. It's only a 4.3 gallon tank and I need to switch to reserve at about 2.6 gallons down from full.
  10. MNXJ650J
    MNXJ650J New Member
    Maplewood, MN
  11. amitlu2000
    amitlu2000 Member
    Durham, NC
    I get between the mid 40s and low 50s depending on what I'm doing. Funnily enough, cruising around between 50 and 80 has netted me the best mileage so far.
  12. Kishkumen
    Kishkumen Member
    Bowling Green, KY
    On my xj550, I get about 90 miles before reserve in the city. On the highway, I get about 160 or so.
  13. tonyp12
    tonyp12 Member
    TX
    Filled up last night and got 48mpg. This is with conservative riding. If I hit the throttle hard alot then its more like 35mpg.
  14. Lefty
    Lefty Member
    Vancouver, BC
    Awesome! I'll fill up today and ride it until I hit reserve. I'm not the most... conservative rider, so we'll see how she goes :)
    C
  15. schmuckaholic
    California
    Before I started working on it, I would typically get an overall of 40. Just to experiment, I tried driving no faster than 55, and one time, did manage to squeeze 47 out of it.
    After doing the carbs, swapping shims and ballpark-syncing the carbs with the vacuum gauges, and maintaining a top speed of 65, the first tank yielded 42.9. The second was better; 47.5. If this keeps up, I will indeed be a happy camper.
  16. nimitz
    nimitz Member
    McHenry, IL, US
    I tend to get a consistent 40 - 42 no matter where I drive but then my carbs are not completely tuned yet. (Synced but not colortuned.)
    But I also drive 60 miles per day during the week round trip to work and back. You can probably count most of my mileage as highway rather than city.
  17. MiCarl
    48.93 MPG today on a 114 mile 2 lane highway ride (50-55).
