What lube should I use on carb CV pistons?
Discussion in 'XJ Technical Chat' started by eric.jones, Aug 29, 2008.
  1. eric.jones
    eric.jones New Member
    Phoenix, Arizona
    Should I lube and if yes, what's the best kind to use on the carburator constant volicity pistons? I've polished them. They pass the clunk test. I applied silicone grease to my diaphragms.
    I know I sound a little silly but I've come this far and dont want to do more harm than good.
    WD40 ?
    Graphite ?
    Litheum Grease ?
    Motor Oil?
    Other?
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    none... you do not need to lube the pistons. if they pass the clunk test, you're set.
  3. Zookie400
    Zookie400 Active Member
    Connecticut
    ditto.....anything you put on there is either going to be washed away by the fuel, or have microscopic particles stick to it and gum up the works.
