What model and year is this?
Discussion in 'Hangout Lounge' started by tscott, Apr 22, 2013.
  1. tscott
    tscott New Member
    Jeffersonville, IN
    I have this bike with no title. So I don't know what year or model it is. The other two I have are 1982 Xj650.
    [​IMG][/url][/img]
  2. 750E-II_29Rbloke
    South Cheshire, UK
    If you post the chassis number that'll help a lot (chacal has a thread on how to ID through the vin somewhere, I'll try find it)
  3. 750E-II_29Rbloke
    South Cheshire, UK
    Here we are :D
    http://xjbikes.com/Forums/viewtopic/t=14577.html
    650's:
    1980-81 XJ650 Maxim USA: 4H7
    1980-81 XJ650 Maxim Canada: 4H8
    1981 XJ650 Midnight Maxim USA: 4W5
    1981 XJ650 Midnight Maxim Canada: 4W6
    1982-83 XJ650 Maxim USA: 5N8
    1982-83 XJ650 Maxim Canada: 5N9
    1982 XJ650 Seca USA : 5V2
    1982 XJ650 Seca Canada: 5V3
    1982-83 XJ650 Seca Turbo USA : 16G
    1982-83 XJ650 Seca Turbo Canada: 16H
  4. chacal
    XH650RJ Seca would be my estimate...........might even be an RJC (Canadian) model since it appears to have a YICS engine.............or engine might have been swapped from something else.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    The man's got better eyes than me! 8O 8)
  6. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    It seems to be a 1982 XJ 650 Seca. Like Len said it could be a canadian 650 if it has a YICS engine or somebody did what I am doing right now and put a 750 seca engine into a 650 frame :)
  7. tscott
    tscott New Member
    Jeffersonville, IN
    yes it has a YICS engine
  8. tscott
    tscott New Member
    Jeffersonville, IN
    can't find the Vin on the neck, is there any other place it would be?
  9. 750E-II_29Rbloke
    South Cheshire, UK
    That isn't good, but then untitled the frame's scrap anyway I guess...
    I think the info you need can also be got from the engine number (right side above the clutch cover, worth knowing anyway in case it's from another model) or from stickers on the wiring loom under the tank (unlikely given the condition but worth a look)
    Also the TCI will have the model code on it's label (next to the reg/rec unit left side) this needs to be matched to the engine code for correct timing curve so may also have been changed if the engine has
  10. k-moe
    It's pretty easy (hough a bit time consuming) to get a bike a new title in the U.S.
  11. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    If the sticker from the left side is missing, look on the right side of the neck and you should be able to find the "short" VIN number. Post the shorty VIN and we can help you decipher it.
    Same goes for the shorty VIN on the right side of the Engine case.
    My guess: 1982 XJ650RJC - Canadian 650 Seca with matching YICS engine.
  12. tscott
    tscott New Member
    Jeffersonville, IN
    OK fellas this is what I found. I was covered with paint/oil or something.
    [​IMG][/url][/img]
  13. tscott
    tscott New Member
    Jeffersonville, IN
    So it looks like its a 1982 Seca. Looks like 5V2, and the other two are 1982 Maxim
  14. bigfitz52
    So if it has a YICS motor, there's been a transplant.
    Check the "shorty VIN" on top of the clutch housing and see what it's prefix is. It won't be "5V2." And it won't match the bike's VIN.
