What needs greasing?
Discussion in 'XJ Technical Chat' started by Sbmaxim, Jul 22, 2007.
  1. Sbmaxim
    Sbmaxim Member
    Every week I try to do something different with my bike, this week it's going to be greasing it up. Where do I need to squirt the magic lube, and what should I use? I have some pb blaster, but could get some wd40 if it would be better.
  2. RickCoMatic
    Do the Pedal Height adjustments for the Shifter and the Brake. You don't want those freezing-up on you.
    Seat hold-downs.
    Clutch lever pivot bushing.
  3. Meighty
    Meighty New Member
    Bend, Oregon
    I have to bow down to pb blaster. I've tried my hardest to get some bolts out with no luck. PB it...and then come out like butta.
  4. MiCarl
    Rear brake pedal pivot. I had trouble with mine sticking just a bit. Needed it free to have the brake light come on with just a tap but not stay on after braking.
