what o rings to mount petcock to tank '83 xj550k maxim
Discussion in 'XJ Technical Chat' started by cgutz, Sep 23, 2015.
  1. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Bike is factory stock.
    I need to take off the petcock. Without buying a rebuild kit:
    What size o ring is used to reseal between petcock and tank?
    Any gaskets or washers around the bolts? If so, what do I need?
    Can these be bought at local hardware?
    Thanks.
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    don't know abut the 550, but I was able to reuse the o-ring on my XJ700N. I just cleaned it and put a little silicone grease on it for good measure. Also reused the same bolts, washers, etc. If you are not going into the petcock and it's not leaking now between the petcock and tank you should have no problem. I've removed mine several times.
  3. XJ550H
    yes the bolts have a special washer under the head. doubt you can buy at hardware store , but you can reuse the ones you have.
    you can use a round o ring just form it into the slots
    or you can buy both from xj4ever.com
    look under fuel system
    http://www.xjbikes.com/forums/forums/xj4ever-supporting-vendor.23/
  4. cgutz
    SE South Dakota
    Does anyone know what size o ring to purchase in case mine is bad? Thanks!
  5. XJ550H
    bring the petcock into the hardware store and size it up
  6. k-moe
    Making sure to buy a fuelproof o-ring (viton preferably).
  7. cgutz
    SE South Dakota
    Had it off today and replaced with original. So far no leaks.
