What oil do you use
Discussion in 'XJ Technical Chat' started by Isaacson06, Jul 28, 2013.
  1. Isaacson06
    Isaacson06 Member
    Des Moines IA
    just wanting to know whats the most used oils in the XJ's ive been using valvaline motorcycle oil for 2 years 10w-40 and now im having starter clutch problems when its cold (first start of the day) the starter clutch doent seem to act up as much but when its hot it acts up alot just wanted to know if you guys think a heavier oil would help ?
  2. XJOE550
    XJOE550 Active Member
    Inverness, FL
    I have used that oil. I also use Castrol motorcycle oil 10-40W. Autozone puts it on sale for $2.99 from time to time.
    I doubt the oil had anything to do with the starter clutch going bad. I'm new to XJ's but I already have learned that some models seem to be susceptible to starter clutch problems. If I'm wrong about this, someone will correct me. Just the sense I got. But I still would think the oil would not be a factor.
  3. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
  4. bigfitz52
    You should be using 20W40 or 20W50 if the outside temps aren't below 40 degrees.
    10W basis oil is for cold weather. As in, doesn't get above 60.
    Remember, a starter that isn't spinning vigorously enough will also appear to be a starter clutch problem.
  5. ERRKON
    ERRKON Member
    Sonoma, CA
    I was using 20w50 Mobil1, until I found a local source of 20w-40. West Marine sells it under its own brand, for outboard motors.
  6. k-moe
    Brand doesn't matter as much as viscosity and rating. 20W-50, 20W-40, (or even 15W-40) for summer/ with a JASO rating/ certification of MA.
  7. luvmy40
    luvmy40 Member
    Y-Town, OH
    K-moe,
    +1 on Rotella T diesel oil, $13.00/gal at Wally World.
    All the rage at the GS resources forum.
  8. Isaacson06
    Isaacson06 Member
    Des Moines IA
    Starter is moving pretty good but anyways I'm going to dump the 15w-40 out and grab some good 20w50 I've notice when it gets really hot outside the bike shifts harder then when cold wonder if the oil is thinned out to much ?
  9. darthraider
    darthraider Member
    Netherlands, Europe
    I've switched to a 20W50 mineral oil this weekend. There's certainly a noticable difference. Starts pretty much the same, but it somehow sounds better and seems to ride better, shifting is very smooth as well now.
