what paint to use for calipers?
Discussion in 'XJ Technical Chat' started by yamaman, Jun 1, 2010.
  1. yamaman
    yamaman Member
    Staten Island, NY
    any input is appreciated, only want to do this once
  2. iwingameover
    iwingameover Active Member
    Duplicolor makes a caliper paint. I've never personally used it but their other product's I've used have done what they say they do.
  3. b0bv1la
    b0bv1la Member
    Mid Ohio
    Any paint will work as long as they are clean. But if you get brake fluid on the paint it will eat it off or if you dont get the fluid off when you clean the paint wont stick either.
  4. bigfitz52
    I use Duplicolor Caliper paint.
    -clean the caliper thoroughly with lacquer thinner prior to painting; don't worry if all the old paint comes off just be sure all the LOOSE old paint is off.
    -pay strict attention to the directions in terms of applying multiple light coats, and within 10 minutes of each other.
    -be sure the part is FULLY "cured" before handling. (Put your nose right on the part and sniff; if it still smells like paint it's not fully cured.)
  5. mlew
    mlew Well-Known Member
    Apex, NC
    I've also used Duplicolor Caliper paint with great sucess. It has held up for the past two years and still looks great. It is available at most auto parts stores.
  6. yamaman
    yamaman Member
    Staten Island, NY
    ok thanks. I sandblasted them and bought gloss black engine paint. I'm doing 4 coats. Duplicolor Caliper Paint Kit was 39.00 at my local auto p arts store and basically included small 6oz can of paint, regular size can of aerosol brake cleaner, a small brush and wooden ice cream stick. Maaaybe enough for 2 calipers. 1 regular size can of spray paint for engines - black gloss - 5.99. Well the surface and the temp is ok and the bottle says wont chip so my fingers are crossed. thanks again
