What size chain? 82 550
Discussion in 'XJ Technical Chat' started by essdot, Jan 26, 2009.
  1. essdot
    essdot New Member
    I Lost my climber book. I need a chain, but there are several sizes. What size usually works for the 550 maxim? THanks again!
  2. Danilo
    Danilo Member
    Vancouver canada
    Likely a 530 type BUT measure for yourself to be 100% sure. The 5 in the chain number refers to the distance bewtween link pins the "3" refers to the space between the side plates or the width of the correct Sprocket
    IE: 3 is 3 x 1/8" =3/8" ,
    while 2 is 2 x 1/8 =2/8"
    Simple once you know the system.
  3. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    You need a 530 chain with 104 links.
