What Size tires do I get? Shop Manual spec confusing
Discussion in 'XJ Technical Chat' started by gfontes, Jul 14, 2008.
  1. gfontes
    gfontes Member
    San Jose, CA
    Hi Folks,
    I did a forum search on this but it was inconclusive.
    I have an '82 750 Seca RH.
    For the tires, the Manual says:
    Front 3.25H19-4PR
    Rear 120/90-18
    On my bike I have Metzlers:
    Front 3.5H19
    Rear 4.25/85 V18
    I'm guessing my bike has a front that is .25" wider than spec'd out by the manual but if I multiply the rear 4.25 by 25.4 mm/in I only get 108mm vs the 120 in the manual. Or am I doing this wrong?
    I have Metzlers now but my racing days are pretty much over. I really want something in between sport and touring...
    What is the forum's generally accepted sizes for this bike, front and rear?
    Any brand recommendations?
    Thanks Much!
    George
  2. MiCarl
    The stock tire sizes are a bit confusing because the front is specified in SAE units and the rear in metric.
    On the front you want a 3.25H19, which isn't available as a size in most tires. The metric substitution is a 100/90 19.
    Rear 120/90 18
  3. Altus
    Altus Active Member
    London, Ontario
    You're right about the front being slightly larger than spec.
    4.25 = 120/80 or /90 -- so that could be just fine.
    For best handling and reliability, go with what the manual says:
    Front:
    3.25/3.50 19 = 100/90 19
    Rear:
    4.50/4.75 18 = 120/90 18
  4. inno87
    inno87 Member
    Nassau County, NY
    me being the bginner i am .. what tires would you all recommend, make and size? i need tires, kinda cheap touring/sport tires b/c mine are a bit dry rotted.
    if possible provide links to the recommended tires.
  5. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
  6. inno87
    inno87 Member
    Nassau County, NY
    *clicking as we speak* thanks alot ass.
  7. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Got a set of Bridgestone Spitfires on my XS750 front and rear for $135.30 delivered from Bikebandit.
  8. mrkil
    mrkil Member
    Toronto ont.
    i got the spitfires local and it cost me $200 :(
  9. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    You have them installed too ?
    I installed them myself.
  10. mrkil
    mrkil Member
    Toronto ont.
    thats plus install.
    did you balancethem too?
  11. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    You had to ask that didn't you!...
    I'm using Dynabeads. This is the second bike I put them on. They work well.
  12. mrkil
    mrkil Member
    Toronto ont.
    ordering right now.
    that'll save me $80 on mounting and balancing costs
  13. inno87
    inno87 Member
    Nassau County, NY
    so i called chaparal, the tires are about 60 each plus tax and shpping, then called the dealership and they said about 50 per tire to mount and balance em. does that sound right?
  14. switch263
    switch263 Member
    Austin, TX
    When I finally get around to getting new tires, I'm going to attempt the mounting and balancing myself. I'll be using the dynabeads rpgoerlich recommends, i've checked out the site and they look simple and effective.
    Personally I say give it a shot mounting them yourself (be careful obviously, don't damage your rims!) and if you cant get it, THEN fork out the cash to have it done. Theres alot of greenbacks to be saved doing it yourself!
  15. Ass.Fault
    First, I dont trust anyone touching my bike. Some greasemonkeys are about as careful as a destructive toddler.
    I pay ~$15 each to have the tires balanced and mounted to the wheel.
    50 bucks better include removal and reinstallation if the wheels too.
    If not, keep looking around
    Inno, do youself a favor and add you bikes info in your signature
    2nd add your location in you acct settings
    3rd add your icon on the xjbikes map, link below
    http://www.xjbikes.com/dfmaps.html
  16. inno87
    inno87 Member
    Nassau County, NY
    i think it might be 40/tire, and thats me remove and bring to them.
  17. mrkil
    mrkil Member
    Toronto ont.
    thats what my local shop wants too.
    i'd rather do it myself and know it's done right.
    i just had no way of balaning before i heard of the dynabeads
  18. inno87
    inno87 Member
    Nassau County, NY
    i just got these for my bike from chaparral, 132.70 shipped for front and rear. my sizes where .....
    Front: 100/90-19
    Rear: 130/90-16 (i just looked at the tire wall and ordered the same ones)
    Dunlop D404's http://www.chaparral-racing.com/Chaparr ... CEADF75E1B
    i called a local shop and it wil be 50/tire to remove, mount, balance, reinstall.
