what sz. pods go on 33mm carbs
Discussion in 'XJ Modifications' started by brokenxj700, Dec 14, 2010.
  1. brokenxj700
    brokenxj700 Member
    Pine Grove,PA
    i want to put air pods on my 85 xj700n the book says the carbs are 33mm so do i go up a sz so thay fit rite,will 35mm pod work,ther is a pill of them on ebay.
  2. NigeW
    NigeW Member
    Bradford, UK
    Measure the outside diameter of the intake, then order pods to fit that diameter.
    Nige
  3. snowyroads
    snowyroads Member
    Tacoma, WA
    my 650 had a 42mm opening at the intake. So that 33mm is not the outside diameter. Youll have to re jet the carbs as well.
  4. mlew
    mlew Well-Known Member
    Apex, NC
    Save that stock airbox, you may want to put it back on sometime. Pod filters present some difficult challanges in jetting to get a good running bike.
  5. brokenxj700
    brokenxj700 Member
    Pine Grove,PA
    thank for the info maybe iall just stay with what i got it runs like a champ,i just wanted somthing diffrent,cool isnt always bedder i guess
  6. kevineleven
    kevineleven Member
    Columbus, Ohio
    But it is always cooler. Try the pods, they get a bad rap around here.
  7. Imthatdude
    Imthatdude New Member
    Philly
    Got pods on my 80.
    Runs great. No jetting involved.
    May just have been pure luck. (luck doesnt come my way often)
    Just put a 45 degree elbow between your crankcase nipple and whatever filter you decide to install on it. (creates slight resistance. I've noticed better throttle response)
    Pods do get a bad wrap sometimes, depends who you ask.
    They add a little/lot of character to your one of a kind machine.
    Give it a try. Whats the worst that can happen? Rejet? Replace airbox?
    Be careful removing your stock airbox. Do it the right way. (Leave the hammer and prybar alone)
    Good luck.
