What WD-40 is Really for
Discussion in 'XJ DIY How-To Instructions' started by k-moe, Nov 21, 2020.
  1. k-moe
    Since this comes up pretty regularly in the refurbishment threads.
  2. Andyam5
    Andyam5 Member
    Luton, UK
    Also good as a thread cutting lubricant for alloy
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I use it to clean, never lubricate. I then wipe off the WD40 and use a proper lubricating oil if required.
    WD40 is also a great label remover.
    Not sure why people think it is a great lubricant/preserver/penetrating oil. Perhaps because it says so on the can?
  4. Pizzaman
    Pizzaman Member
    north Seattle
    Had a Ford in the early 80's that frequently when raining out would stall out. Figured out if I sprayed some WD-40 into the distributor cap I could go on my way without waiting for it to dry up
    XJ550H, Timbox, Franz and 2 others like this.
  5. k-moe
    Careful with that. There are two formulations of WD-40; one is very flammable.
  6. Timbox
    Timbox Well-Known Member
    That just helps it dry faster :)
    Darth Gunner and jayrodoh like this.
  7. k-moe
    Or sets the distributor on fire if you're impatient. Seen it happen.
  8. cgutz
    SE South Dakota
    We used to use WD40 cans to make flame throwers...not very safe for a young teen...
    Darth Gunner and k-moe like this.
