whats the best way to bypass headlight relay?
Discussion in 'XJ Technical Chat' started by kalinin, Jul 25, 2007.
  1. kalinin
    kalinin Member
    NE Ohio
    Whats the best way to bypass the headlight relay? My relay has died and $70 from Yamaha seems a bit much to me.
  2. Robert
    Get a standard relay from an electronics shop for about $5 and use it instead. Get a 30 amp unit and you'll be golden. Good luck and let us know if you have further questions.
    (Reference the XJ650RJ wiring diagram in the Haynes manual)
  3. kalinin
    kalinin Member
    NE Ohio
    Ok....I got the 30A relay....now what? lol The new relays 4 contacts are: 12V in, 12V out, On/off switch, Ground. The wiring in the bike has a white, black, blue/black, red/yellow. I tried a couple of positions and no luck. I know the black is ground....
  4. RickCoMatic
    How did you identify that as the Headlight relay?
  5. kalinin
    kalinin Member
    NE Ohio
    According the the Haynes Manual....and when I swapped the relay from the turnsignals the headlight comes on....
  6. MiCarl
    Turn signal relay and headlight relay are not interchangeable.
    Headlight relay has four wires going to it. Colors are White, Black, Blue/Black and Red/Yellow. (Turn signal relay has three wires).
    You can bypass the relay (light on with key on) by connecting the Blue/Black wire to the Red/Yellow wire.
  7. RickCoMatic
    Bypassing that relay is a sure-fire battery killer.
  8. kalinin
    kalinin Member
    NE Ohio
    ok maybe it wasnt a turnsignal relay, either way the headlight came on with the key...
