What's the blue wire in the pickup coil harness?
Discussion in 'XJ Technical Chat' started by jtricer1973, May 8, 2019.
  1. jtricer1973
    jtricer1973 Member
    Mississippi
    What's the blue wire in the pickup coil harness? Connects to a bullet connector by the igniter. Other end is behind a screw behind the gear shift. I'm not finding it on the schematic.
    it connects to the diode block and starter cut off relay
  3. Franz
    Is could be the wire for the neutral switch underneath the crankcase.
  4. XJ550H
    he has a 550 the switch is behind the shifter/chain cover
    650 and 750 have the switch under the motor in a very hard place to get at
  5. Franz
    Yes the 900f is the same too.
    XJ550H likes this.
  6. jtricer1973
    jtricer1973 Member
    Mississippi
    Thanks. What sort of connector should it have to fit behind the screw. Mine is just the wire.
  7. k-moe
    A flanged spade terminal, or a ring terminal with a notch to slip over the screw, or an ordinary ring terminal if you remove the screw for installation.
  8. jtricer1973
    jtricer1973 Member
    Mississippi
