whats the trick for getting caliper piston in
Discussion in 'XJ Technical Chat' started by cruiserlover, May 27, 2018.
  1. cruiserlover
    cruiserlover Active Member
    denton texas
    On my 81 and 82 650 maxim the pistons were stuck inside the calipers.The 81 had been sitting and so i decided to use the caliper off the 82.Its front brakes had been moving before.I used a grease gun and got the piston out of the 82 caliper.I used one more container of grease on the other one and it just did not seem like it was ever going to get loose.So,now I have cleaned everything.The grease makes a huge mess.I got the caliper rebuild kit.It came with 2 thick orings and 2 thin ones.It was a kit compatible with different models.I see the thicker gasket fits in the groove of the caliper barrel.I had to use a pick to get the old one out.The new one just doesnt go into the groove and stay there.It even sticks out a little.I am thinking the piston going back in will keep it in place and also force the gasket to expand a little to get up in the groove and stay there.I tried putting the old piston back down with no seal in place, with it in place, neither works.I plan on using grease on the piston and maybe it will slide down.I know I can also use a c clamp.But, what is going to prevent it from catching on the gasket that is sticking out slightly from the groove,pulling it out of the groove,making it drop down into the barrel> I think if I put some of the heavy black grease on the gasket groove the gasket might go in there and stay put. Both the old piston and the new replacement one are both quite tight and neither goes willingly down in the hole.It needs to be this tight for correct operation, but I am at a loss.I can make it go down in the hole just as i made it reluctantly come out of the hole.I am afraid of catching the new gasket.What do I do?
    Did you thoroughlly clean the piston seal grooves?
    Did you lubricate the new seals with brake fluid?
    What brand rebuild kit is it?
  3. cruiserlover
    denton texas
    I got the piston in.I used a little motoroil on the outside of the piston and I used some grease to hold the seal into the grooves,I am still not sure that happened.I used a c clamp.The piston was very reluctant then finally it gave in and I was able to use the clcamp and get it down easily after that.I have put the through bolt in, the pads in their respective slots.ran the long bolt up through the caliper to where the 12 mm nut on top can be installed.There still is a little daylight between the caliper and where it snugs up against the forks.On an exploded drawing I dont see that there should be another washer or anything on top of the caliper between it and the forks.Its like the caliper is at a very slight angle,not completely seated across the fork leg on the bottommost portion.But it is completely as it should be on all other areas.I am curious what happened to that seal as I forced the piston down in the hole.I hope it didnt come out of the groove or I have just wasted a huge amount of time. K and L brand
  4. Rooster53
    Anything other than grease specifically formulated for a hydraulic systems should not be used. They can cause the rubber to swell and possibly brake lock up.
    Cleaning the groove as k-moe suggested is very important, and using just brake fluid as a lubricant to assemble is also OK, although the red rubber grease designed for hydraulic systems makes assembly a bit easier.
    Stumplifter, Jetfixer and k-moe like this.
  5. mlew
    mlew Well-Known Member
    Apex, NC
    If you have to use a c-clamp to get the piston in something is wrong. You can damage either one by doing that,
    After cleaning the caliper and piston, test fit it. It should slide in easily with NO force needed. Then install the new seals with lube. Lube the piston and it will go in with hand pressure, turning the piston while pushing it in helps not to snag the new seal .
  6. cruiserlover
    denton texas
    I used a c clamp, it went in.It did not slide in easily and it for sure did not come out easily.I used some black grease made by valvoline synthetic blend made specifically for bearings,brake components, cv joints and so on.Plus the amount was very minute.Once i got past about 1/4 inch in the piston went in easily.if you have ever done disc brake pads on a car you know that to apply even pressure on a caliper piston you lay a block of wood or a wrench across the opening and use a c clamp to compress it.I dont have any compression washers and all the dealers are closed on mondays so i will have to wait till tuesday to see how bad I messed up if at all.Usually I do.This piston reminded me of a tappet i struggled with on the other head I bought for my parts bike.For weeks i could not get it in.once I got it perfectly aligned and using both thumbs to guide it practically fell in.I would be surprised if the brake works but hopefully it will.
    One question, what is the trick to keep the rubber seal in its groove while passing the piston by it.I used some grease to hold it in place, but I hope i didnt pull it out by snagging it with the piston.I have another caliper if i screwed it up.I know the piston keeps them in place once the whole thing is assembled,no way for the seal to come out then.
  7. cruiserlover
    denton texas
    the SEAL has to be in BEFORE the piston is put in.No way around that. My fingers are crossed.
  8. cruiserlover
    denton texas
    There should be no need for excessive pressure placed on the Caliper Pistons to replace them back into the Caliper Body outside of normal use of the C-clamp when Caliper Piston is pressed into a Caliper Body which has no build-up to cause the circumference of the Seals to be reduced. (I pasted this from our forum)
  9. mlew
    Apex, NC
    Read carefully. I said to test fit the piston first to make sure it fits in the bore easily and does not bind. Them remove and install the seal.
  10. cruiserlover
    denton texas
    I stand corrected.Sorry.
  11. cruiserlover
    denton texas
    I was told to just stick to one thread.My pipes the guy cut off right behind the heat shields.I have a set of stock exhausts and mufflers.Those things weigh a lot.I can get some shorty mufflers for about $60 for the pair.or even cherry bombs designed for a car.it wont be stock, but I am afraid of breaking off a bolt.I am not a purist but the shortys are almost as loud as the cutoffs.If you werent going with stock pipes and didnt want a 4 into 1 what would you use?
  12. k-moe
    The seals should stay in the groove without the use af any grease. Are you sure that you bought the correct seal kit? From who did you buy it?
  13. cruiserlover
    denton texas
    its made by k and l.I dont remember which company.It may be the wrong seal.the piston is identical.the seals look the same more or less.the one I removed was 37 years old.The new one wont stay in the groove. It will stretch and go in the groove, but sticks out when let go of.It was supposed to fit multiple bikes.probably because multiple bike models have the same brakes.
  14. Anthony Byrne
    Anthony Byrne New Member
    Wexford
    Hi ,a question regarding the front brake on my 81 Yamaha xj 650.i cannot get the brake to be very effective,I renewed master cylinder seals,first,new pads ,no fluid leaks, but spongy feel on leaver could bleed daily getting a little air out,
    I would like to drive it but not confident
    Breaks not what they should be,
    Any help would be great.thanks
  15. k-moe
    Please start a thread for your issue.
  16. k-moe
    There's the problem. K&L make some really good parts, but they have a few things that just aren't correct.
    Start a conversation with Chacal. He will have seals that fit correctly.
    Chitwood likes this.
  17. cruiserlover
    denton texas
    sounds like a good idea.the piston looks good though.shipping costs are ridiculous.
  18. Craig B
    Craig B Active Member
    Ontario, Canada
    If you used motor oil on the seal or petroleum based grease I strongly suggest you throw them out and get new ones and thoroughly clean the calipers.
    The rubber used on brake systems will react very poorly to anything oil based. They will swell and leak or jam up.
    Either way not a good scene.
    Only use grease designed for brakes or just good old DOT3.
  19. cruiserlover
    denton texas
  20. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    if I remember correctly the seals are angled. with the thicker part going to the back of the caliper, so it has to be the right way round.
      File size:
      97.6 KB
    Craig B and cruiserlover like this.
  21. Jetfixer
    Silicone grease on the seal and a smear around piston it should slide right in. Silicone grease can be bought in the plumbing aisle at most hardware or home improvement stores xj4ever sell it as well
  22. cruiserlover
    denton texas
    wow.did not know that.thanks.
  23. cruiserlover
    denton texas
    the piston went in easy enough,but the seal wouldnt stay put.bensalf just posted about the seal being different in one part than another,.why does a manual never mention that.Its like if you want to fix it yourself you have things stacked against you.
  24. k-moe
    The seals I used were uniform in all dimentions, and could be installed either direction.
    Rooster53 and Jetfixer like this.
  25. cruiserlover
    denton texas
    thats the way this seal is.the groove does not have any variation,nor does the rubber replacement seal.if there was a variation i think it would be easy to see.This kit listed a number of bikes it is supposed to fit. Including a virago. A conversation with chacal shows his kit or his aftermarket version also fits multiple bikes, either front or rear calipers.His kits are way more expensive. getting the piston out with grease shows how much the piston was stuck,after 31 years most of those years the piston was stuck probably.This should have been an easy task once the piston was set free. there are very few mechanical aspects to it if the parts are the correct one. the pads only go one way. the caliper bolts to the forks only 1 way. the brake line, banjo bolt, only 1 way. this little piece of rubber is really annoying me.
  26. k-moe
    And that sir, is the issue. Mistakes happen in manufacturing and packaging (take all of the errors in the XJ service manuals as an example). I strongly suspect that the seal is not correct for the machine, despite what the package it came in says.
    Craig B likes this.
  27. cruiserlover
    denton texas
    I have to agree.
  28. kosel
    MInneapolis, MN
    I recommend spending the extra to get the parts from @chacal. I ordered a caliper rebuild kit from him, followed the write-up here on the forum, and was able to successfully complete my very first, ever caliper rebuild. The right parts and the right steps make the job faster and more pleasant while making the results safer.
  29. hogfiddles
    I've never seen one like that
  30. bensalf
    yorkshire ,england
    yep, that one is from a much later xj600 uk model 1990, and the whole bike's were like that, ie inside piston , outside piston , front left , front right ,and rear,
    6 seals in all
    stu
