Whats This
Discussion in 'XJ Technical Chat' started by wereiswally, Jan 1, 2009.
  1. wereiswally
    wereiswally New Member
    Hi
    New to XJs
    I starting to try to retore this 81 XJ hooked up a battery it would turn over but now wont turn over
    I think it may be electical when I switch the kill switch back & forth the item pictured clicks
    Its not the battery eather i am using a car battery with jumper leads
    May be in the switch some times I get a liottle turn over thought it may be earth
    Fuse box not looking to good but works tested fusers
    I crossed the two solinoed points with a screw driver & it tuns over
    Any help or ideas would be grat
  2. WiseManSage
    WiseManSage New Member
    Armidale, NSW, Australia
    I may be wrong but it looks like the blinker flasher box pictured above.
    The XJ looks to be in bad shape, it looks like to be alot of work you have ahread of you.
    Goodluck.
  3. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Wereiswally, You DOG. I'll give you $50 USD for your lift! Very sweet. Sure beats sitting on a bucket all hunched over whatver you're working on.
    WAMAXIM
  4. bigfitz52
    I'm a 550 guy so I can't be 100% sure which one that is BUT: Based on the symptom you're describing that may be the safety relay or sidestand relay you have there. These bikes have a safety interlock system that prevents the bike from cranking if it is in gear and the sidestand is down. (Or if a problem makes it THINK that.) The sidestand has its own relay too, and a problem with that, the sidestand switch, the neutral switch or the safety relay itself can cause it to not spin. You'll need someone with a book or the same bike to identify what you have pictured by the color of the wires. The SAFETY relay itself can be unplugged as a diagnostic measure, to bypass all that silliness but you really shouldn't leave it unplugged.
  5. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I broke down and bought the Air/ Hydraulic lift from Harbor Freight. I love it!! Its the best investment I have ever made as far as tools go. I just put my bike up there and its so easy to work on rather than bending over and wreaking my back. That relay looks like the side stand safety relay. You need to get a wire diagram and trace those wires out. Try to bypass your side stand switch first before you jump that relay out. Good Luck
  6. SQLGuy
    SQLGuy Well-Known Member
    It's the starting circuit cutoff relay. When it's "on" it should be feeding 12V to the starter solenoid coil. The fact that it's clicking sounds like a good thing.
  7. wereiswally
    Bit of a job allright
    May get to much for me when a XJ on ebay in good nick whent for $1500 Aus recently
  8. wereiswally
    Replaced the solenoid with a spare I had from a XS650
    turns over now but wont fire
    i removed the carbys can see now why she wont fire
  9. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    yuck, petrified petrol.
    I hope your in a cleaning kinda mood :)
  10. wereiswally
    i have removed the Diaphragms float bowls & jets can I soak the rest in a kero bath with out removing the butterfly shaft
    Two of the floats wont move seems to be very much stuck in one position
  11. wamaxim
    Vancouver, USA
    Are the carbs in the above post Hitachi's? It looks like the 2 center carbs have a slanted side to the hat. I am assuming that the slans are in another piosition on the other 2 carbs. If I remember correctly I think Rickomatic said that the slant on the had meant Hitachi and the dimople in the top meant Mikuni.
    If so, I have a set of Hitachis.
    Am I right?
  12. flash1259
    flash1259 Member
    W.R. Wisconsin
    1 of 2 things
    starter circuit cutoff relay or the sidestand relay.
    hope this helps you
  13. bigfitz52
    DON'T SOAK THE CARBS!!! Unless you take them completely apart first. The THROTTLE SHAFT SEALS are delicate little buggers (that you can't even see) and you do NOT want to wreck 'em.
  14. wereiswally
    I want to soak them & I don’t wish to remove the butter fly shaft (To hard I here)
    I will pick up some carby spray cleaner & give a gentle clean up as best I can
    Every thing that was removed is soaking in kero
    These carbys Hitachi are the carby tops meant to face the front & the two centre ones face the back?
    How do you remove the floats to clean them?
    This bike was a Courier bike so it seems the side stand switch has been by passed
  15. SQLGuy
    Remove the four float bowl screws, then remove the bowls. The floats are held in with a pin that may just fall out when you take the bowl off. If not, just push it out and the float and float needle can be removed. You will probably need to scrape off the old bowl gaskets.
  16. schmuckaholic
    California
    Not as hard as you might think. I've done the throttle shaft seals on my Hitachis. Have a gander at this file and see if that helps. If the bowls are that bad, I'm not holding out much hope for the seals, truth be known. You'll be wanting a good-fitting phillips screwdriver to get the butterfly screws out, though.
    Nope... best I know, all the slants on the carb hats should face the rear. If funding permits, Chacal just started stocking those carb hats. Chrome and Gold flavors. [Witness my pitiful attempt at writing ad copy]. :mrgreen:
  17. wereiswally
    I think this is to much work for me to do anything with so if there is anyone in the Sydney Australia area out there who wants a parts bike for the right price PM me
  18. bigfitz52
    Oh, come on now you're giving up too easily. I would buy a spare rack o'carbs off eBay. They show up all the time and can go for as little as $30USD. As bad as yours are, it shouldn't be too hard to find a better set.
    I would at least get the bike running before I decided whether to continue the resto or scrap it. Maybe you can find a better bike as a starting point since you already have a "parts bike." An XJ is a worthwhile endeavor once you consider the rewards.
  19. schmuckaholic
    California
    I agree with Fitz. You're probably just feeling a bit overwhelmed right now, and that's understandable.
    Don't rush things; take it one step at a time. You've already got the carbs broken down and the various bits soaking, and that's a good chunk of the work right there.
  20. wereiswally
    OK OK
    Ill clean carbys up & see how I feel then Once she starts ill probable change my mind.
  21. Fishmaster
    Fishmaster Member
    Spring, TX
    wereiswally,
    I just finished rebuilt my carbs and I took a lot of pictures during that process. I'm creating a photo gallery that I will upload to myphotoalbum.com probably this weekend. It will shows how to put them back together, for the cleaning process you can find a very good detailed posts here.
  22. taildragger
    taildragger Member
    "Don't give up the ship!" Capt. James Lawrence
    I had a devil of a time with my allegedly "clean" xj550 carbs.
    It took me several weeks of poking, prodding, cleaning, fixing and redos then one glorious day it finally started!
    Persistence pays.
  23. wingnut325
    wingnut325 Member
    Havelock North Carolina
    I've had sets that bad and they are a bit of work but when she runs the first time you will forget all about it. One way to help loosen up the junk is to soak the whole carb, diaphragms removed and bowls off in kerosene for a couple of days. It didn't seem to damage the throttle shaft seals at all. The other product I use to get the old fuel off is varnish remover. Now that you do not want to get on the throttle shaft seals
  24. Fishmaster
    Fishmaster Member
    Spring, TX
    SIMPLE GREEN and hot water will work well also.
  25. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    wereiswally,
    Listen don't give up just yet. I was terrified of taking apart my carbs just a week or two ago. There are lots of HOW-TO's on this site for your carbs, they really walk you through step by step. Afterwards you'll realize it's not that bad. Let us know how you make out!
    Mac
  26. yamaha4life
    yamaha4life Member
    OH---IO
    trust me wereiswally after you get those carbs cleaned everything else on the bike feels like a cake walk...just take your time and she will fire up and purrrrrrrr and that relay is the starter relay book said headlight but its not on mine its the starter relay headlight was down by the ignition box
  27. Forgewizard
    Forgewizard New Member
    Central Florida
    Keep at it wereiswally! My Maxim's carbs were pretty varnished up and full of "goo" too when I inherited the bike. It had been sitting for years. I cleaned what I could in the carb bowls and floats, cleaned the spark plugs, dumped a couple bottles of carb cleaner in the fuel, hooked the battery to a charger/starter and kept turning over the bike. She eventually fired off, choking and sputtering.
    Not being an actual cycle mechanic I opted to take it to a local shop for tuning and have been driving it every day since!
    Just don't give up on the old beast - your pipes get rusty too if you just sit around on the sofa all day!
    Cheers,
    Kim
