what's your opinion? spark plug reading
Discussion in 'XJ Technical Chat' started by som1somwhere, Sep 23, 2014.
  1. som1somwhere
    som1somwhere Member
    United States, Illinois
    non specific order. at 3 turns out. before tune up.
    new plugs and decreased to 2.5 turns out. plugs are 4-1. obviously too lean so im thinking maybe i need to do 3.25 turns or 3.5 turns. what do you guys think
  2. Gulrok
    Gulrok Member
    Washington
  3. som1somwhere
    som1somwhere Member
    well they say on this site most bikes are 2.5 -3.0 turns and i honestly thought 2.5 was lean but if you think otherwise then im quite shocked. im rather new to the tuning bit. im more or less rethinking it to maybe a 2.75 turns would do the trick over my original 3.25
    There isn't enough color on the new plugs to tell anything. How many miles have you ridden on the bike with the new plugs? None of those look dangerously lean (though I wonder about that blob that appears to be on the ground strap of #1), so you can ride it until there is enough color to read, or you can shop for a Gunson Colortune so you can see what the mixture looks like as you adjust it.
    What sort of tune up did you do?
  5. som1somwhere
    som1somwhere Member
    well i rode on those for a solid 5k as my avg rpm. for about 30minutes. i guess that isn't a long enough time to be able to judge it huh? i guess ill put them at 2.75 turns and ride her for a few days and go from there. and as for the tune up i just threw some new plugs in her and cleaned the air filter. nothing too much. maybe do a vaccuum resink whenever i get a good solid color going.
    dont worry moe. i did my valves and floats beginning of the year ;)
  6. bigfitz52
    #2 is seemingly scary lean. Don't look at the insulators, look at the "flame ring" (the part with no threads that the ground strap sprouts from) and the ground strap below the bend. #2 has no color.
    Check (or just replace) your little rubber caps on the intake manifold vacuum spigots. They can LOOK fine yet be hard as rocks.
    Be careful here. XJs love to run lean, right until they blow up. That being said, 30 minutes at 5K works out to about 30 miles, does it not? Not enough of a ride to pick up much color. Take it out for an afternoon and run through a full tank of gas. I would go to 2.75 turns like you said, and ride it if it's running seemingly OK. See what kind of color your plugs pick up after 150 ~200 miles. Don't fret the insulators; with today's gas those take time to build color. Read the flame ring and the ground strap below the bend.
    Dude, I think the "spots" on #1 and #2's ground straps are places where white deposits have flaked off (damn ethanol-laced gas anyway.)
  7. som1somwhere
    som1somwhere Member
    see i was thinking the flaking was because 1&2 (4&3) were running leaner than 3&4(2&1) so i spruced those 2 up a quarter turn as seen in the first picture 2 of them are lighter which since i threw them in a box after pulling i have no way of telling what cyl they were and can only assume the leaner ones are 3 and 4. i have them at 3.25 atm and ill need to reduce a half turn tomorrow and then ill give my findings
  8. bigfitz52
    "Assume" has the expected results: Makes an "ass" out of "U" and "me."
    Invest in a ColorTune. You may need carb work (including throttle shaft seals.)
  9. Polock
    left looks good , right is a little lean, two center ones might not even be firing
  10. som1somwhere
    som1somwhere Member
    it more n likely does. i was probably going to redo the carbs this winter.
  11. quebecois59
    If they are lean at 3 turns out, it would make them worse if you turn them 1/4 turn in, because your carbs will get less fuel in. You'd better turn them 1/4 turn out.
  12. som1somwhere
    som1somwhere Member
    the first picture has 2 a little lean looking but i dont know much but i corrected those by richening the 2 suspected cylinders. to try and even htem up with the others that looked rich to me.
  13. Planehue
    Planehue Member
    London,Ontario
    I'm looking for an experienced opinion on my plugs as well. I'm thinking 1 and 2 are lean and 3 and 4 are ok.
  14. Gulrok
    Gulrok Member
    Washington
  15. k-moe
    It's never a bad thing to ask for confirmation.
  16. Gulrok
    Gulrok Member
    Washington
    Fair enough. You're right.
  17. Polock
    those pictures in the links were great when you had a 386 pc and a 9600 dial-up modem
