wheel swap?
Discussion in 'XJ Modifications' started by BAREfoot, Nov 10, 2010.
  1. BAREfoot
    BAREfoot Member
    Kelowna, BC - Canada
    does anyone know what spoked wheel bike i can swap my wheels with..i was hoping on finding some spoked wheels... anyone done a swap?
  2. bigfitz52
    Your 400 Maxim might just be similar enough to the earlier 400 twins that had wire spoked wheels. There was a "Heritage Special" based on the old twin shock SOHC bike as late as '82 and it had wire spoked wheels. I'd start there.
  3. BAREfoot
    BAREfoot Member
    awesome... i'll definately check it out... might be hard to track one down... but we'll see.... not that i don't like the mag wheels..but i like the "old" look of bikes.... thanks man...
  4. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Search for older XS 400's (the SOHC ones) or maybe a 650, but may be sprocket mounting issues on the 650's I believe the bolt pattern is different
  5. xyxj650
    xyxj650 Member
    Fergus Falls MN
    I will tell you right now the tires are not a direct swap. I did do a wheel swap on my 400 maxim. My friend and I parted out a 400 special with spoked rims. i had to swap out the complete 400 special front end to make it fit correctly(easy swap out). Also the sprocket on the rear tire is not the same along with the spacers for the tire. I had to have some cut for my bike.
  6. BAREfoot
    BAREfoot Member
    seems like a headach just for some wire..bahhhh! but the complete front end (forks and tripple clamps) fit fine in the tubestem with no issue?.. then that's something to consider... as for the sprocket.. well it's not hard to order a new one.. and it's not expensive so that's easy.. and i guess i just have to find someone to fab some spacers... i'm going to build my own hard tail.. so i'm wondering if i should get some wheels first and measure to them... but at the same time.. i'd never get my other wheels in if i decide to since the frame would be too small... what to do... haha..
    now who's got a 400 special that they want to sell me the front end????anyone haha?
  7. Orange-n-Black
    Memphis Area
    What about Virago wheels?
  8. BAREfoot
    BAREfoot Member
    i checked them out.. the rear is a 15 inch.. not a big deal..just don't know how wide it is... quick question... will my breaks usually swap over..or do i have to go with the brakes from the other wheel... i see that a lot of them are dual disk or even drum.. mine are single front and drum rear..
  9. Orange-n-Black
    Memphis Area
    Not sure, come to think of it I think all Viragos are shaft drive so that wouldn't work on your 400 would it? Might look in to XS rims but you would have to convert the rear brake to a disc setup with a MC. Maybe some Kawasaki Vulcan rims from the same period would work for the rear,but the fronts had dual disc's.
  10. BAREfoot
    BAREfoot Member
    still haven't found anything that'll work... this 400 sucks! haha... really wish it had an easy swap.. the rear i'm not worried about since it's going to be hardtailed anyway..so i can make it fit.. just the front i'm worried about if it'll fit my breaks or not...
