wheel valve stem size?
Discussion in 'XJ Technical Chat' started by althomas101, Sep 2, 2013.
  1. althomas101
    althomas101 Member
    Baltimore, Md
    I'm fixing up a XJ750RJ for a buddy and I'm getting ready to order tires and valve stems. His bike has a tubes, but after researching the forums it seems that the bike is designed for tubeless. So I need to know what size valve stems it uses if anyone knows, worst case I'll remove the tire/tubes and measure, but I'd rather keep it a rolling chassis for convenience if at all possible. Thanks in advance for any help offered.
  2. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    send a message to Chacal, he will know exactly what size you will need. Also, you will find his outlet invaluable for oem and aftermarket parts as well as his technical advice. His link is at the very top of the page to the right.
