where are brass anti tamper plugs
Discussion in 'XJ Technical Chat' started by bikerpoole1, Apr 15, 2009.
  1. bikerpoole1
    bikerpoole1 New Member
    hiya im trying to remove the brass anti plugs only problem is where are they i think i have found them is the ones with a big brass plug then a litte one right next to it on engine side near the top woul be very helpfull if someone could post a pic thanks
  2. sushi_biker
    sushi_biker Member
    The plugs are tiny. Top of the carb, towards the back.
  3. TIMEtoRIDE
    Do what?
    They are at the front of the carbs, above the throttle plate, engine side.
    If you look in the throat infront of the throttle, you will just see the tip of the Pilot needle. It's tiny.
  4. sushi_biker
    sushi_biker Member
    Oof...that's what I get for posting before morning coffee. Thanks Time.
  5. TIMEtoRIDE
    Yeah, I thought you were looking at the DeLorean carbs. :p
  6. chacal
    7.03mm diameter, to be exact...........
