Where are the parts on the drive shaft?
Discussion in 'XJ Technical Chat' started by ecologito, May 5, 2014.
  1. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    I am looking at the Yamaha Parts and there seem to be quite a few parts at the end of the shaft where it connects with the U joint.
    All I see on the parts I have is the groves at the end of the shaft, a C clip at the end of the shaft and the groves in the U joint. Is the oil seal supposed to be pressed into the U joint?
    Just trying to get a visual of what I may need to order from Len.
  2. MiCarl
    #s 32-34 are at the final drive end of the shaft. They've drawn them exploded off the front end.
    #35 I believe is the circlip that goes in the u-joint end of the shaft. Not sure/don't recall what #36 is.
  3. chacal
    Some driveshafts use a wire clip at the front end of the driveshaft, as well as a circlip......the XJ650RJ Seca being one of the models that DO use the wire retaining clip (all driveshafts used the "rear" cirlcip).
    This wire fits into a groove cut into the splines of the shaft, and prevents the driveshaft from backing out (towards the rear of the bike) of the yoke/u-joint.
    The shaft circlip (located behind the yoke/u-joint) prevents the shaft from walking into the yoke (i.e. towards the front of the bike).
  4. ecologito
    NASCAR Country, NC
    Ok, now that makes sense. I see the circlip around the shaft so I guess is all a matter of fitting it into the groves of the U joint.
    Thanks a lot for the clarification, now I need to do some cleaning, and at least replace brake the brake shoes. The wheel bearings can wait until I have this puppy road ready.
