where can i get a new start circuit cutoff realy from
Discussion in 'XJ Technical Chat' started by dean.james, May 14, 2014.
  1. dean.james
    dean.james New Member
    west yorkshier
    i have looked and looked but can not find one and now i am at my wits end with this bike all i want to do is ride and have some fun now it is finished but first the diedo blows up and now this will i ever get to ride it :?
    i need a new start circuit cutoff relay like today.
    i have looked on net and rang round some dealers and still no look
    can some one help me please
  2. Greenbike
    Greenbike Member
    Milton Keynes, England
    I think that it is possible to use a normal four terminal (blade) relay but you need a diode as well. In the meantime, you might well be able to bypass the relay. until you can replace it.
    Exactly which XJ is it? There are differences in the wiring between different models.
  3. bigfitz52
    The way to "bypass" the starting circuit cutoff relay is to simply unplug it. This is the quickest and easiest way to troubleshoot a "safet interlock" issue; with the cutoff relay unplugged, all of the safety stuff means nothing and the bike should be able to be started.
  4. Greenbike
    Greenbike Member
    In that case, the diagrams in the Haynes manual, figures 6.25 to 6.27, and section 34.3, all in the Electrical System chapter are wrong.
    34.3 states that the relay contacts are closed, 'on' when the relay is energised, and this is what the diagrams show.
    The diagrams would be clearer if they followed the convention of showing all relay contacts in the unenergised position. That is, when there isn't electricity flowing through the relay coil. (The solenoid is just another relay, it just switches a large amount of amps)
    I haven't checked the wiring diagrams at the back of the book, because I do not know which model it is and I've not time to go through every one.
  5. chacal
    Hey Dean, we do have these relays in stock, but of course we are in the USA, so you won't be able to get it "today"!
    The relay schematics in both the Yamaha and Haynes can be both confusing and mis-labeled (especially in Haynes, since they try and jam all the various model schematics onto a few pages; the schematics are correct but the labels----what they are, and what their applications are ----are wrong in some instances).
  6. bigfitz52
    A few points: Yes, Haynes is often misleading or downright wrong. This is not limited to the Yamaha book.
    I have personally unplgged the safety cutoff relay on a 550 to diagnose an issue with the safety interlock circuits and it started; or I wouldn't have suggested it as a troubleshooting step.
    And finally, the bike in question is a 550 which is not covered by the Haynes.
  7. Greenbike
    Greenbike Member
    Any progress, dean.james?
  8. dean.james
    west yorkshier
    it is a Xj550 maxim seca 1982
  9. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    It is one OR the other, it is either a maxim OR seca.
