Where does this piece go? Xj650 starter
Discussion in 'XJ Technical Chat' started by Sarah, May 26, 2017.
  1. Sarah
    Sarah maxim-um fun
    Indiana
    Wondering about the washer that the red arrow is pointing to. I just disassembled this starter and cleaned it out, it was chock full of black grime.
    All washers pictured in the repair manual diagram seem to be accounted for, and it doesn't really seem to intuitively fit anywhere...so I'm confused lol :confused:
    Any help would be greatly appreciated! Thanks!
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Looks like it could the insulating washer for the positive power post.
  3. hogfiddles
    +2 (sort of)
    It's the rubber seal for the insulating washer/sleeve (goes on the outside of the case, over the positive terminal). The insulator itself is plastic or bakelite, and fairly long. The aquare end of the posive terminal fits into a square recess on it.
    Since you're in there go ahead and get a rebuild kit so you have new brushes. The insulating sleeve is prone to get brittle and crack, so a new one of those is a good thing as well.
  5. Sarah
    Sarah maxim-um fun
    Indiana
    Thanks everyone! Definitely wanted to make sure that I had everything back together in the right places.
    I do have a kit on the way, my brushes are at minimum length, and I sure did crack that little plastic sleeve! Oops lol :p
  6. k-moe
    It's over 30 years old and made from a plastic that's pretty brittle even when new. Not cracking one on disassembly is a trick.
