Where to buy steel braided brake lines?
Discussion in 'XJ Modifications' started by kalinin, Mar 18, 2007.
  1. kalinin
    kalinin Member
    NE Ohio
    I want to upgrade my XJ650J's brakes to steel braided lines....anyone know of some good places(cheapest) to get them?
  2. jasonajwilson
    jasonajwilson Member
    chilliwack BC Canada
    I got mine from my local yamaha shop. I think they were 130.00
  3. bosozoku
    bosozoku Member
    Albany, Oregon
    Cheapest option is to make your own- the parts are about half the cost of a pre-made setup. All you need to build brake lines is access to a bench vise, a hacksaw, and a few other common tools.
    http://www.oldbritts.com/brake_line.html
    You'll need two lengths of -3 brakeline, four banjo fittings, one long banjo bolt, and 7 new brakeline crush washers.
    Use the longer banjo bolt at the master cylinder, with a hose to each caliper. Remove the original cast brakeline tee and park it with your old brake lines.
  4. danno
    danno Member
    Union Springs,New York
    You may want to give CycleBrakes.com a try . I bought a custom made line from them,and it was about $110,delivered. A great improvement over the stock line which wasn't great 25 years ago,when it was new. They offer a variety of color,length,and banjo fitting options.And these lines don't have the awkward looking adapter fittings that most 'universal" lines require.They will include new banjo bolts and crush washers with your order free of charge,if you request them. I am very pleased with my purchase from them. Their tool-free # is 1 800 805 2118. Hope this helps,and best of luck to you in your search.
  5. FloridaBiker
    FloridaBiker Member
    Jacksonville, FL
    I go to my local Hydraulic shop.
    (try Aeroquip, Hydraulic supply, etc)
    and have them made to length as needed.
    Prices are reasonable, and quality is first class.
  6. Altus
    Altus Active Member
    London, Ontario
    Bought mine at my local Yammarobber from the catalog - got Russell line and fittings. Replaced the stock two-piece hose assembly with one long 42" line. Total cost was about $50 Canadian.
  7. kalinin
    kalinin Member
    NE Ohio
    Thanks for all the replies.....I'll check them all out!
  8. todubbad
    todubbad Member
    topeka kansas
    Aeroquip.
  9. ridz
    ridz Member
    Ride hard and live free!
    to crimp the end onto the brake line thats seems to be the biggest prob...they are calling it liability 8)
  10. bosozoku
    bosozoku Member
    Albany, Oregon
    A brakeline you make with parts from suppliers like Aeroquip,,Russell or Barnett use threaded fittings, not crimped.
