which master Cyl. is "stock" on 1985 xj700 Maxim?
Discussion in 'XJ Technical Chat' started by Preacher, May 20, 2017.
  1. Preacher
    Preacher New Member
    Globe, Az.
    I've owned the above cycle for 10 years but it had only one side of the front brake that was connected. I decided to get both sides working, so bought a longer bolt, with 2 holes, to connect both brake lines together, but when I went to bleed it and get pressure on hand brake, it would not do it--1/2 a quart of fluid. So I figured I needed a master cyl. rebuild kit, so ordered one off ebay. Nothing on that kit fit my plunger that goes inside the master, and I contacted the supplier and they ask me if my master is "stock"--I suppose meaning did it come with the original bike, for they say they sent the right kit. I bought this bike used, so I don't know. So I'm asking you guys who have original "stock" if you can look under the master and tell me what it says--on mine, it says "nissin 6h5". I live 100 miles from Phoenix so it is hard for me to go a junkyard there to find this out. Thank you.
    longer bolt to connect the two hoses. nope
    here is your brake system brakes ft.JPG parts list as well.
    your brale line should connect to the side of the mc
  3. XJ550H
  4. chacal
    XJ650 non-North American (dual disc) models, XJ650RJ Seca, all XJ700, XJ750-X, XJ750RL, and XJ900RK and RL models: the cylinder body will have the word NISSIN cast into it along the larger rear facing side of the cylinder body, and have the size 5/8 cast into the forward face of the cylinder body just to the left of the fluid outlet port (where the brake line attaches).
    The 6h5 number is probably a manufacturing date code, not a part number, and does not help in identifying your master cylinder.
    If you could post a picture that would be most helpful.
  5. Toomanybikes
    Tsawwassen bc
    This is pic of Xj700n mc in my driveway
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    It looks just like the one on my 85 XJ700N. Got my parts from Chacal and everything fit perfectly.
