Which Master Cylinder
Discussion in 'XJ Modifications' started by AndyXJ, Feb 13, 2015.
  1. AndyXJ
    AndyXJ New Member
    Falkirk - Scotland
    Hi.
    Apologies for the green question, but I've not been able to confirm the answer yet! I've spent days (yep, days) reading and re-reading posts and the parts catalogue and I think I know what I'm looking for, but just wanted to check.
    I'm currently rebuilding a XJ650 Maxim back to factory(ish) spec, but I'm going to put twin front brake discs on it. Am I correct in saying that if I use a XJ750 or XJ1100 Maxim front brake master cylinder, I'll have the filler cover and mirror hole at the correct angles?
    Andy
  2. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    It depends on your handlebars. If the MC is from a maxim with the "buckhorn" bars and you have relatively flat handlebars, then it's not going to be at a correct angle.
  3. AndyXJ
    AndyXJ New Member
    Falkirk - Scotland
    I didn't realise there were flat(ish) bars on a Maxim, apologies for not being clear. My 650 does have 'Buckhorn' bars on it.
  4. AndyXJ
    AndyXJ New Member
    Falkirk - Scotland
    I enjoy being the first to try things so will report back with my findings.
  5. chacal
    If you have the stock 650 Maxim handlebars, then you'll really need to use the XJ750 Maxim/Midnight Maxim master cylinder, as it is the only one which has a "tilted" mounting configuration AND has a larger bore to handle the dual calipers........
    FtUp likes this.
  6. AndyXJ
    AndyXJ New Member
    Falkirk - Scotland
    Perfect, thanks. Apologies for the misunderstanding earlier, I had no idea that the 650 Maxim came with different bars, I always assumed they were all the same. You live and learn :)
