!!!!Who knows what this relay is??????
Discussion in 'XJ Technical Chat' started by Codysc843, Mar 16, 2020.
  1. Codysc843
    Codysc843 Member
    Sc
    1982 xj750
    Omron 4u8-00
    Omron 4h7-01
    Both are relays what do they go to and how could I bypass them an answer soon would be nice thanks
    https://www.xjbikes.com/forums/threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/ the answer is in the link
    4U8-00 side stand relay bypass is leave it out of the bike
    4H7-01 Starting/Ignition Cut-Off/Neutral Safety relay: bypass is to connect the 2 red/white wires together
    this relay works when bike is in neutral or clutch pulled in when bike in gear if it does not work when bike is in gear the clutch safety switch is broken or sidestand is down
    I do not recomend bypassing safety switches
