Will a 550 tank fit on my Maxim 650?
Discussion in 'XJ Technical Chat' started by ShiftyEddie, May 6, 2010.
  1. ShiftyEddie
    ShiftyEddie Member
    Grand Blanc, Michigan
    I have a Yamaha Maxim 650, and the tank is rusted inside with small holes
    in the bottom. I can have it repaired by gas tank renu for about 150.00,
    but have the option of picking up a pretty decent Maxim 550 tank.
    Any ideas if this will work?
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    Nope, won't fit without some serious modification...
  3. grmeyers
    grmeyers Member
    Asheville, NC
    I was under the impression that a xj550 and a xj650 tank was the same. Learn something new every day.
  4. bigfitz52
    Nope. Almost nothing "550" will fit the bigger bikes, except some of the switch pods, etc.
  5. TIMEtoRIDE
    You can upgrade to a Maxim 750 tank for some extra range,
    You should be able to clean and seal it yourself for less than $150.
