Will that be Regular or Super?
Discussion in 'XJ Technical Chat' started by JaiFer, Jun 24, 2015.
  1. JaiFer
    JaiFer Member
    Northern Ontario
    I've followed this site for a year now and I've haven't heard this subject discussed. What grade of fuel is recommended? I have used both and don't see difference in performance. Opinions anyone?
  2. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    I run 93 octane in my 700 because it's air-cooled and I've heard that 93 burns slower, thus cooler. And 93 contains less ethanol.
    And besides, nothing is too good for my XJ.:cool:
  3. hogfiddles
    I use 87 in EVERYTHING.
    Stumplifter likes this.
    ^^ What he said. ^^
    Our bikes are realtively low compression, and do not require higher octane. A higher octane fuel does not "burn cooler". Octaine is a measure of a fuel's ability to resist detonation (burning due to the heat in the cylinder instead of the spark event; higher compression engines cause the air/fuel mix to get hotter during the compression cycle than a lower compression engine will). Unless you have a high compression engine you are wasting money by using high test fuel.
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    87 + a double shot of seafoam.
    Gary H.
    Beekman likes this.
