Wiring brake light.
Discussion in 'XJ Technical Chat' started by CaptHeavy, May 27, 2016.
  1. CaptHeavy
    CaptHeavy Member
    Clermont, FL
    Alright guys I finally finished up most of my bike. Had to wire a whole new harness and rebuild carbs and all sorts of stuff.
    Anyway! I've got to wire up the tail/brake light. PO had cut the wires coming from the rear brake. I've got what looks like a brown and a yellow wire. Which is which and where am I putting them?
    Also, I ordered a rebuilt master cylinder and it's got two male prongs for the brake switch. Any idea what their for? Which is which? Do they both need to be connected?
    Sorry for the noob questions, learning as I go. Thanks guys!
  2. CaptHeavy
    CaptHeavy Member
    Clermont, FL
    Figured out the rear brake. Now what about this front brake?
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    er, for the brake light.
    the male prongs are on the brake light switch fastened underneath the brake lever post.
    there should be 2 wires from the harness to the switch
    which bike?
    stu
  4. CaptHeavy
    CaptHeavy Member
    Clermont, FL
    750. Where to I connect these two leads? I'd assume I run power from the fuse panel to the switch and then from the switch to the brake light?
  5. wingwax
    wingwax New Member
    Hey all, mind if I piggy back on this thread? I've got a similar issue with my '82 Maxim. I just mounted a new master cylinder and it has to prongs to marry-up to the brake wire, but the current brake wire looks like the one in the attached photo: s-l500.jpg
    Anyone know how I can make the new one work?
  6. k-moe
    It's really best to start your own thread.
    Simple rewire with spade terminals on one end and barrel terminals on the other using the switch that is on the new master cylinder.
    One question. What is the bore size of your new master cylinder?
  7. bensalf
    yorkshire ,england
    yes, that would be it, I see you have rewired the harness.
    so as you said, run a wire from the ignition switched fuse ,to the switch. then from the switch to the brake light
    stu
  8. wingwax
    wingwax New Member
    Looks like the new one is bigger: 16mm. Am I in for some brake locking nightmares?
  9. k-moe
    It should be fine.
