Wiring Help, PLEASE!!!
Discussion in 'Hangout Lounge' started by xj750, Dec 8, 2009.
  1. xj750
    xj750 New Member
    I have an 82 maxim 750. The turn signals work but don't blink all of the time. When i was playing with the harnesses, if I put them just right they work fine. So....does anyone have any idea of where to find a wiring diagram so that I can rewire the bike?? Any input will be helpful. Thanks.
  2. RickCoMatic
    Before you re-wire the Bike, ... check the Alternator Brushes.
    Replace the Fuse Panel.
    http://www.centechwire.com/Merchant2/me ... _Code=FB-6
    Clean >> Or eliminate << certain contacts.
    Some of the wires that are joined with Bullet-ends and Cylinder-Type Terminal Ends have the connection to facilitate manufacturing.
    You can eliminate mechanical splices and Solder the Wires to reduce the number of places that would be troublesome.
    Just Cleaning, Shining and Re-crimping the Terminals does help.
